Old 08-29-2010, 04:28 PM   #1
Adony's Avatar
Shower / Tub Enclosure Questions??
This past week we experienced something in our new Wildwood TT that I'm not quite sure of how to deal with... When using the shower I noticed that water would drain off the enclosure walls to the tub edge, then follow the tub front edge around until it dropped to the floor. At first I thought we were not level but after checking we were very close to level... I now have two questions... In picture 1 below, the bottom edge of the enclosure is not caulked or sealed to the tub.. Is this normal or should it be caulked (I rather believe that it is not an issue as the enclosure must overlap some kind of lip on the tub but wanted to ask... Picture 2 shows the path that the water takes before it drops to the floor.. any ideas what can be done here? I apologize for the poor quality of the pictures..
ID:	3284   Click image for larger version
Adony is offline   Reply With Quote
Old 08-29-2010, 05:49 PM   #2
Villa Estate 392FLFB
The_Stuff's Avatar
id caulk that up
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 08-29-2010, 05:57 PM   #3
NWJeeper's Avatar
Others here have had that problem. I believe there are some plastic triangle shaped pieces you can find at Walmart, Home Depot or Bed, Bath and Beyond that have sticky tape made for the problem of water running off the edge of the tub.
Do not caulk the gap for the shower enclosure it is made to be that way. Ours is the same. On the floor pan (tub) there is a flange that runs up behind the surround by an inch or more, there is no way for water to get behind the tub.
Ed & Wendy
www.nwjeepn.com
Old 08-29-2010, 10:20 PM   #4
Just curious, but when the camper is level, is the tub level? We have had the same set up in our last two and I used them all of the time as well as our DGD and never had this problem. Just a thought.
Donna=Me Tom=DH
2 DD's-grown, 1 DS grown, 1 DIL
4 DGD's, 1 DGS, 1 Pekingese(7/1/1999-6/18/2016)
2011 Shamrock 23ss
2000 Suburban 1500 4 X 4
ngts camped 2016-24 so far. reservations for 11 more
ilovecamping is offline   Reply With Quote
Old 08-29-2010, 10:32 PM   #5
bmg
We have the same problem. In fact we're camping now and I just took a shower and noticed water running under the door and down the hall toward the bedroom. We've raised the tongue and the front jacks and that has helped some, but it hasn't solved the problem. It's my guess that the tub was not properly leveled during assembly.
bmg is offline   Reply With Quote
Old 08-30-2010, 01:00 AM   #6
TF-Kevin's Avatar
I have the same problem, so i ran a bead of silonce to channel the water, it seems to help, plusi lowered the shower curtain also
Kevin
Kevin & Debbie and our little dog Emma
2004 F-150 Lariat 4X4 Ext Cab 5.4
2010 Flagstaff Shamrock Hybrid 19
TF-Kevin is offline   Reply With Quote
Old 08-30-2010, 05:30 AM   #7
cardinal4fun's Avatar
As for caulking you are correct. There is a lip that the wall sections sit on/over. There is no need to caulk, it allows any moisture behind the pannels to drain.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
