Old 10-02-2015, 07:37 PM   #11
Makes sense, OC- any idea for what I might be doing wrong? Should I opt for scissor jacks instead of these screw jacks?
Don't have any idea (pictures)how you are set up. I just know I don't have any movement, front to back, up or down or side to side.
Old 10-02-2015, 07:47 PM   #12
Left Coast
Screw type jack-stands are what's being tried
Old 10-02-2015, 07:55 PM   #13
Fulltime family RVer
Side to side movement- stabilizers
Ok, so here is the current setup:
- in the front, I have the SteadyFast Stabilizers going 2 ways:
- in the rear, I have electric stabilizers (they lift he camper slightly before I stop) and have SteadyFast running across the width of the camper:
- I've tried 2 positions for the screw jacks- just ahead of the axles and split between the tires and rear stabilizers. No difference in either position.
Here's the passenger/door side:
Here's the driver's side:
Oh, and forgot- I have Rotochoks between the tires.
ependydad is online now   Reply With Quote
Old 10-02-2015, 08:05 PM   #14
I have X homemade JT's on the front, nothing on the landing jacks going front to back, Use Bal X chocks, front to back homemade JT's on the back and the reinforced stab jacks in the front of the axles. I lift the axle jacks until the motor just about stalls and the rear ones at least 1" -2".
ID:	90491   Click image for larger version
ID:	90492   Click image for larger version
Name:	Homemade front stablilizer (Driver side upper).jpg
ID:	90493   Click image for larger version
Name:	Homemade front stablilizer (Passenger side upper).jpg
ID:	90494   Click image for larger version
Name:	Right rear frame.JPG
Name:	Left rear frame.JPG
Old 10-02-2015, 08:13 PM   #15
So, similar concepts all around EXCEPT that I'm not getting much lift out of my axle jacks.
With the screw jacks in the rear, when I crank them up- I take weight off of the rear stabilizers. Which if I then readjust, it takes weight off of the screw jacks. It was a lose/lose situation.
So, I think I might look for something different for stabilizers at the axles.
Old 10-02-2015, 08:18 PM   #16
Why have both on the rear? Reinforce the stab legs and put some pressure on them. I lift the rear at least 1"-2".
Old 10-02-2015, 08:25 PM   #17
The creator of the SteadyFast system does not have good things to say about rear electric stabilizers and recommended these there.
I also tried the screw jacks just ahead of the axles with similar (lack of) results.
Old 10-02-2015, 08:31 PM   #18
So, essentially he admitted his system needs help. All I can tell you is what works for me. I'll just use my crude homemade/modified stuff.
Until you triangulate across the trailer (BOTH WAYS) you are going to have movement.
Old 10-02-2015, 08:32 PM   #19
Ehh- I heard the same thing about JT StrongArms. I can't talk about your homemade stuff.
Old 10-02-2015, 08:37 PM   #20
Left Coast
Could you use the screw ones as a pivot and raise front high, slide stands back to in front of axle, let front down to level, then use rear to slightly lift.......
stabilizers
