Old 10-02-2015, 09:54 PM   #21
Ehh- I heard the same thing about JT StrongArms. I can't talk about your homemade stuff.
The homemade JT's are just square tubing and Heim joints, no slop in the joints. I raise the landing jacks about 1/4"-1/2", tighten the lock bolts and then lower. IMO, you have to have the X across the front and enough weight on the rear to stop the side to side motion designed into the jacks. The more vertical you get the rear legs, the more resistance to horizontal movement you get. Putting big blocks under them defeats that resistance. Have fun.
Old 10-03-2015, 01:27 AM   #22
Fulltime family RVer
I'll give that process a shot.
2012 Ram 3500 DRW/crew cab/long bed/4x4/4.10 gears pulling an early 2013 Sabre 36QBOK
Old 10-06-2015, 06:00 PM   #23
Tfort's Avatar
Oldcoot, if you don't mind me asking, what thickness tubing did you use on yours and did you make the brackets that connect the ends or did you find some pre made that works? I have been looking at the JT system and cannot see where it should cost that much when I could build it for probably less than half. Also you tighten it before lowering it all the way down? This doesn't stress the landing gear at all?
2000 F250 CC 4x4 7.3L diesel
15 Salem Hemisphere Lite356QB
Tfort is offline   Reply With Quote
Old 10-06-2015, 08:30 PM   #24
I used 0.075" 1" sq. wall tubing for the inner and 0.090" wall 1.25"sq outer. I welded nuts in the ends for the 5/16" Heim joints. IMO, there is very little stress on the landing jacks or the stab jacks as the weight of the trailer is holding the pad firmly on the ground and the upper end is held firmly by the attaching hardware. I have used these same struts on 2 trailers since 08 and have had no problems.
Old 10-06-2015, 09:28 PM   #25
Welp, all setup in Moab. I tightened the landing gear and then lowered the jacks somewhat. The rear, I raised like I normally do (seemingly that 1"). I haven't put the axle jacks in place yet.
We'll see how it does.
Old 10-06-2015, 09:51 PM   #26
I may need to reread this thread but I did not see where supports under the slide outs were mentioned. We have had rocking with all our trailers ( both 5th wheel and TT's). The best thing we have found is putting supports under the slide outs.
Arenablanca is offline   Reply With Quote
Old 10-06-2015, 09:58 PM   #27
Left Coast
'Till a tire goes down.
Old 10-06-2015, 10:28 PM   #28
My owners manual specifically calls them out and says to NOT use them.
Old 10-06-2015, 10:32 PM   #29
Who Dares, Wins
doc73's Avatar
I do not think any modern slide allows for their use to avoid damage when things settle.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon-EOW 11/22/2017
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 10-06-2015, 11:38 PM   #30
TURBS's Avatar
Not recommended by any means!
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
stabilizers
