Old 09-30-2015, 10:25 PM   #1
Fulltime family RVer
Side to side movement- stabilizers
As of now, I have Rotochocks between the wheels and have tried originally the UltraFab Eliminators (originally) and now the SteadyFast system. I've always had a fair amount of movement. It's definitely better than without- but, I can tell when either kid rolls around in the bunkhouse (3 and 11). I can only imagine "what" they feel with us in the bedroom (aghast! gasp!).
I have read here over and over that adding stabilizers just ahead of the axles should take out the remaining movement (except when someone is coming up the outside steps and step stabilizers takes care of that). Recently on my blog, the creator of the SteadyFast system indicated that a good bit of movement is coming from the rear electric stabilizers and that I would get good results if I added screw stabilizers back there.
So one of my recent Amazon orders was a pair of screw jacks. I first tried them at the rear of the camper and other than taking weight off of the rear stab jacks, I couldn't tell a difference.
I moved the jacks to just ahead of the axles and twisted them up as far as I could go. AND... no difference!
So seriously... for you all with 40'+ fifth wheels who claim you've got "rock steady" setups. Please tell me wtf I'm doing wrong!
Old 10-02-2015, 01:39 AM   #2
I know I'm wordy. So, longest story short:
A) am I setting my stabilizers wrong?
B) is "rock steady" not really a thing?
I get that it's a house on a suspension and all; but your claims make me question it.
Old 10-02-2015, 11:15 AM   #3
Left Coast
B and B has rear stabilizers on his Rockwood....might ask him. Strongarm style
Old 10-02-2015, 12:05 PM   #4
dieselguy's Avatar
I've always had 33' - 37' fivers and have always had JT Stabilizers on them resulting in little "wiggle" or side to side movement. I don't see how adding jacks under the frame will get rid of side to side movement. Fiver's will always have "bounce" since they most always rest on their suspension ... any version of triangulated brace arms like JT's will eliminate 90% of wiggle if setup per manufacturers guidelines. Adding 4X4 or 6X6 blocks under your jack feet to reduce the amount of extension will help
dieselguy is offline   Reply With Quote
Old 10-02-2015, 12:37 PM   #5
Every bit of stabilization helps but always some left. I believe most of remaining is side to side bigger blocks and shorter jacks helps
Harkerr is offline   Reply With Quote
Old 10-02-2015, 04:52 PM   #6
Major's Avatar
Part of the wiggle, especially from side-to-side is from the weight of the RV sitting on the tires. Tires wiggle. The stabilizers are just that; stabilizers.
Most don't really take the weight off the tires unless your RV has a hydraulic leveling system. That's a different story as you typically won't get wiggle because these take the weight off the tires.
Doug and Becky Ridgeway
2014 Blue Ridge 3600RS
2014 Ford F-350 CC 4X4 DRW 6.7 PSD
Troy, NC
Major is offline   Reply With Quote
Old 10-02-2015, 06:57 PM   #7
I guess I'm wondering if I'm setting mine up appropriately. The UltraFab Eliminators are essentially JT Knockoffs. The SteadyFast system is the same triangulating concept just implemented slightly differently.
I think it is definitely side to side movement that I'm seeing from sitting under the camper while people moved around.
Old 10-02-2015, 07:00 PM   #8
I tried cracking these up as much as I could, but with the small handle- I hit my limit pretty quick. I'm a weakling.
Old 10-02-2015, 07:29 PM   #9
I do not put blocks under any jacks and extend them as far as necessary to slightly lift the 5er. My 2 sets of stab jacks have the legs reinforced so I am not worried about bending them. If you look at the design/construction of the stab jacks, they will move side to side if you don't get the legs as near vertical as possible. The axle stab jacks take the bounce out of the suspension.
Try the following, just extend the stab jacks down about 6" without them touching anything and then grab ahold of either leg and jerk it in or out and it will slide back and forth, the jack assy slides in another channel on the frame, that's why they do not take the side to side movement out if they set on tall blocks.
Old 10-02-2015, 07:33 PM   #10
Makes sense, OC- any idea for what I might be doing wrong? Should I opt for scissor jacks instead of these screw jacks?
stabilizers
