Forest River Forums
Sunline User Photos
Old 01-23-2012, 06:27 PM   #1
Mountainmanbob's Avatar
slide maintenance
Regular room slide maintenance can prevent operational problems on the road
Slides, slide outs, slide rooms, are one in the same. They are those nifty RV features that turn small spaces into larger ones.
Often, however, they act up, usually due to preventive maintenance. Slides require maintenance and occasional adjustment. RV owners should have a little knowledge about their workings just in case of a malfunction.
 Slide maintenance is important.Some RVers fail to realize that slides can be closed manually. Somewhere in your rig is a crake used to manually open and close slides. Look on a wall in the basement or other storage areas of your RV.
Early versions of slides were hydraulically operated so operating mechanisms required a lot of space. This type of slide cannot be pushed back in manually without releasing the hydraulic pressure. The motor and pump are located under the slide. Also, between the coach battery and the control solenoid on the pump motor is a heavy duty battery cable. A fusible link is located near the pump with this cable. It is a smaller gauge wire that will self destruct in case the pump motor overloads.
A good rubber seal
lubercant helps prevent
problems.Electrical problems top the list of reasons slides fail. See if the fusible link burned out or look for corrosion at the battery or the solenoid terminals. Clean the cables and connections annually to eliminate problems while on the road. It is also a good idea to lubricate the extended hydraulic ram with a heavy duty silicone lubricant.
Use a portable battery booster to provide temporary power to close a stuck slide. Have someone crawl under the slide and locate the pump motor. Attach the red booster box cable to the cable connection on the solenoid connected to the cable leading to the battery. Then connect the black clamp to a clean frame mount. Be sure that the cables do not bind as the slide is pulled in, and that the red clamp does not hit any metal.
Newer slides have electrically operated gear track or screw mechanism. Most gear driven units have a single electric motor operating a mechanism that have a mechanical disconnect allowing the drive to be disengaged so that the slide can be pushed back in.
With the slide extended, crawl under the slide and locate the operating motor and the disconnect lever. If these units fail the problem is usually a fuse or a circuit/overload protector. The fuse should be marked in the coach fuse panel that is under the hood on gas units or in the bin area near your batteries on diesel coaches. It is not located in the circuit breaker panel inside the RV.
All slides require regular maintenance of the rubber sealing gaskets and wipers. Protect-All Slide-Out Rubber Seal Treatment is a popular foam lube that is spread on all rubber components. That should be done every 60 days to keep the rubber from drying out.
The tracks and gear slide mechanism should be lubricated with something like Protect-All Dry Lube. It is an orange liquid for visibility, but dries leaving a lubricant that will not attract dust and dirt. It also is a rust inhibitor that will maintain the integrity of the track surfaces.
Mountainmanbob is offline   Reply With Quote
Old 02-02-2012, 04:46 AM   #2
Mountainmanbob, thanks for the information. Too, I am glad you brought this up as it has been on my mind.
While I have not used yet, I purchased some Protect All Slide-Out Rubber Seal Treatment (RST) when I made an order for some other items.
After receiving this product, I contacted the manufacturer to inquire about its use on the windows’ rubber gaskets. Here is the manufacturer’s response:
You can use RST on the window seals. You can also use our Protect All - All
Surface Care wax. The advantages in using Protect All are additional UV
protection and no worries about where the RST goes. RST is strictly for rubber
seals while Protect All is a multi-surface product usable on almost every
surface, inside & out.
Best Regards,
Patrick Huber
VP, Ops & IS
Protect All, Inc.
www.protectall.com
(800)322-4491
Additionally, I purchased the Protect All Slide-out Dry Lube with the same order.
In searching for quality products to use, the consumer has to distinguish between a manufacturer’s sales pitch and truth. Often times, the end user is the best source, which leads me to my question: Is anybody a long term user of these products? If so, for how long and what has been the results of use? If you don't use these products, what do you use?
Thanks.
2012 Rockwood 8314BSS
2011 Chevy
Camping, Dutch Oven Cooking, and Homebrewing
campdohbrew is offline   Reply With Quote
Old 02-06-2012, 03:53 PM   #3
MikeInColo's Avatar
Thanks Mountainmanbob! Excellent information!
I'm gonna have a look at my slide following your guidelines. I'll wait until this spring when it's warmer!
MikeInColo is offline   Reply With Quote
» Online Users: 662
150 members and 512 guests
1l243, 4bnabird, 64c10, alphadog99, anitag, armye7, autorot8, Bearcat55, bidesheng, BigKidzFun, Bigmatt, BigR, Bingo71, BlakeB, bob34787, BonnieSeip, bowtang2001, bush, bwbarnes, Cafjackracing, Cairdeas2111, camping4us, campkng, Capsfloyd, carsonizik3, Cascade Bob, cdbus, cnkc, CRZ, cstover, Dakota EV, dashonthedash, davidjb, daw592, ddemme, depo, Derekcan, djorgensen3, dkwalsh, dnaraG_1M, doc73, donh, doosterhouse, Drmstx62, drobert, DTingle, EL99jl, emljr, extremebike, feerobk, forthefunofit, fpdeod, FreedomTracker, Gary Bridges, gator14, gbowman143, gmw65, growe, Hamblen, HemiCab, Hilgy, Interface Admin, itech, Itsthetwoofus, Janet H, jar3316, jechst, JedinWI, jerrygallion, jjm901, jmswms, jobren4, jordan, Juan.Cortes, Justbryguy, ken0042, Kevin-and-Julie, kixonrt66, KKapa, KoolAide, KyDan, lacroixyvon, ldmcmahan, LFugate, LuckyMcBRIDE, Maddog378, martin73, mbfree66, melbornj, mike54, Mrgary, mtibod1955, NanaKaren, NINA, Nursx2, ohiobill, Old car, Pa-cj5, Papa Roo, pgordemer, pg_rider, pmsherman, Poppy Bill, pryner, punkaccountant, Puyallup, radurecka, rbrandon, realebill, Redheaded blue tick, Retired63, rickthelen, RJHuser, Sailfish Bret, samiller, savdog, Scriggs1, SDENN4281, shavard, sideout1961, silverwing, SimchaSabre, skullskidr, snjparham, Snowsail, southernsky, sphinx, steeleshark2, Tee, Test Account, thom01, tmmar, travyp, treadwelll, Triguy, trudinator, True Believer, tshayn, tsmcmillen, TTNewbees, T_LMurphy, UPGRADER, Vette4trcr, vlite2011, wellcoman, whj77372, Wildcat Chris, win, y01lxb, yworrydog
Most users ever online was 944, 03-04-2012 at 01:27 PM.
Close [X]
