Old 08-20-2016, 10:46 PM   #1
Bglover's Avatar
Slide out alignment
I have a 2015 Salem cruise lite 262bhxl with large slide using schwintech system. Sometimes the back or rear lags behind the front on out and in movement. Should this be happening I have had it at camping world and independent dealer several times for this and they say all is well. Sometimes the front will come in and the back won't and you have to go out again and start over.
Bglover is offline   Reply With Quote
Old 08-20-2016, 11:35 PM   #2
SeaDog's Avatar
I may be wrong but when you run the system either out or in hold the button in the selected position for aprox 5 seconds after the slide has stopped moving this will sync the motors or so I had been told, I may be off base here its just my HO
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 08-21-2016, 06:58 AM   #3
Head Rambler
It's not normal. Do you know where the controller is?
If so, Have you looked at it when the problem occurs to see if there's any errors?
Have all the electrical connections been remade from the battery to the motors?
If not, I suggest that be done, especially between the controller and motors.
Does the lagging happen randomly, or only when leveled, or only when not leveled, etc.?
How often does it happen? (every other time, Once in a while, randomly)
Is there any unusual noise when it is happening?
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-21-2016, 09:04 AM   #4
LTRVing's Avatar
Check the Lippert channel on YouTube, they explain how to sync the Schwintech slides.
The Millers, enjoying life, spending the kids inheritance.
LTRVing is online now   Reply With Quote
Old 08-21-2016, 02:39 PM   #5
raspivey's Avatar
That's correct...I think it was seven seconds per LCI. If they get too far out of sync the controller will shut it down. I'd hold mine once every ten cycles or so and I never had any problems with it.
2012 Chevy Tahoe LTZ - HD tow package
Old 08-21-2016, 04:49 PM   #6
Bglover's Avatar
It happens both level and not level. It is random and then it will start back and be that way several times. Just leveled it and run it in and out several times and it did it each time three times it would run one side in or out and stop I would move it in the opposite direction until it stopped and go again. I just don't want to be stranded camping and this lock down on me.
Old 08-22-2016, 11:19 AM   #7
Head Rambler
Did you find the controller box?
Gotta go campin!
Old 08-22-2016, 12:44 PM   #8
Bglover's Avatar
Yes and didn't see any flashing of the codes. I guess I will move it in and out and sinc it and see what i get. I have found out how to override the system in a bind to get it in if I have to.
Old 08-22-2016, 02:12 PM   #9
Head Rambler
That's the first thing to try since you didn't see any errors.
Let us know if that works.
Gotta go campin!
alignment
