Forest River Forums
Sunline User Photos
Old 07-29-2011, 12:07 PM   #1
Slide-Out Lubrication - Dry Moly Lube
I saw a recommendation to use a dry molybdenum lubricant on the slide-outs. Anyone have any experience with this? From what I have read, this spray goes on wet then dries and forms a lubricating seal.
I bought a can but have not used it yet. Thought I would spray it on an area of the frame and see what it looks like after it dries.
I know the manufacturer says the slide-outs don't require any lube but I use my trailer on the coast and if I don't lube it pretty often, the slides will start making a squealing noise and even trip the auto breaker when it gets bad enough.
I have been using Jig-A-Loo which has worked well but doesn't seem to last long. Always looking for something better.
Dennis
La Vernia, Texas
2007.5 Dodge 3500 Laramie, 4WD, Dually, 6,7L Diesel
2008 Forest River Sandpiper 375QBQ
dd5087 is offline   Reply With Quote
Old 07-30-2011, 06:52 AM   #2
Lou Amadio
herk7769's Avatar
Dry Lube is "Da Bomb"!
Anything "gooey" will attract dirt and accelerate wear and noise.
You can also try Slide-Out Dry Lube Protectant - Protect All
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 4)
herk7769 is offline   Reply With Quote
Old 07-30-2011, 08:42 AM   #3
Moderator
TheSasks's Avatar
We live in the country on dirt roads and our main slide squealed so bad it scared the dogs. Tried nearly everything to get it to stop and the only thing that worked was Fluidfilm. Sprayed everything down, left it soak for 10 min and then wiped it off, and then put the slide in and out 6 or 7 times and it finally stopped squealing. Talked to the dealer and the svc mgr said they have had the same thing and Fluidfilm was the only thing that worked as well. Haven`t seen any buildup of dirt since either but like I said I wiped it all down after applying it prior to moving the slide. Fluidfilm is one of my favourite products for working on old tractors etc to lube and free up stuff.
John & Deb
2008 Dodge Ram 2500 4x4 Laramie Hemi Megacab
2011 Flagstaff V-Lite 30WRLS
TheSasks is offline   Reply With Quote
Old 07-30-2011, 11:00 AM   #4
MrT
MrT's Avatar
+1 on the Protect-All product. Works great on my slide.
2010 Rockwood 8314SS Signature Ultra Lite
2007 Nissan Titan Crew Cab SE 4x4
Reese Dual-Cam | Tekonsha Prodigy P2
Camping Nights: 2009 (8) | 2010 (17) | 2011 (32) 2012 (~35)
RIP: 1997 Jayco 1208, 2000 Jayco Heritage Laurel
MrT is offline   Reply With Quote
Old 07-30-2011, 11:45 AM   #5
Are you saying that the Moly Lube will be "gooey"?
Dennis
La Vernia, Texas
Old 07-30-2011, 03:14 PM   #6
Lou Amadio
herk7769's Avatar
I am not familiar with that product as I use the RV Slide Lube spray.
However Lubing the running grear with grease (like white Lithium or bearing grease) or oiling it with 3 in one or motor oil, will definately qualify as "gooey."
Old 08-03-2011, 12:28 PM   #7
extremebike's Avatar
I use dry moly on the hitch pin and used it for years on the hitch ball when I had a popup. It works great but be sure to shield areas where you don't want the stuff as it will not come off. It goes on wet and 5 minutes later it is completely dry to the touch and will not hold dust. Use cardboard to shield areas when spraying.
extremebike is online now   Reply With Quote
Old 08-04-2011, 08:22 AM   #8
I am going to test the Moly Lube on a small area so I am looking for the Protect-All product locally but have been unable to find it. I know I can buy it on the web but the shipping is expensive. I will keep looking, haven't exhausted all the local stores yet. The Protect-All web site says that Walmart carries it but I have yet to find one that has it. Walmart doesn't even show it on their web site. They only list the Camco product, I have used that and was not impressed.
Dennis
La Vernia, Texas
Old 08-07-2011, 09:26 PM   #9
Interesting thing happened to me today as I was using Protect All Dry Slide Lube... it set my propane detector off... looked at the ingredients and they are using propane as a propellant ...well at least I know the detector works
2010 Rockwood 8281SS Signature Ultra Light
2009 Dodge Ram 2500 w/6.7 Cummins
bobsquarepants is offline   Reply With Quote
Old 08-08-2011, 11:48 AM   #10
Dry moly
LPS makes dry moly and below is the factory link.
LPS Labs:High temperature Lubricants, FORCE 842 Dry Moly Lubricant
Look at the industrial fastener outlets. If they don't have LPS they will have something similar. Good Luck!
» Online Users: 662
150 members and 512 guests
1l243, 4bnabird, alphadog99, anitag, armye7, autorot8, Bearcat55, bidesheng, BigKidzFun, Bigmatt, BigR, Bingo71, BlakeB, bob34787, BonnieSeip, bowtang2001, bush, bwbarnes, Cafjackracing, Cairdeas2111, camping4us, campkng, Capsfloyd, carsonizik3, Cascade Bob, cdbus, cnkc, CRZ, cstover, Dakota EV, dashonthedash, davidjb, daw592, ddemme, depo, Derekcan, dkwalsh, dnaraG_1M, doc73, donh, doosterhouse, Drmstx62, drobert, DTingle, EL99jl, emljr, extremebike, Falcon35, feerobk, forthefunofit, fpdeod, FreedomTracker, Gary Bridges, gator14, gbowman143, gmw65, growe, Hamblen, HemiCab, Hilgy, Interface Admin, itech, Itsthetwoofus, Janet H, jar3316, jechst, JedinWI, jerrygallion, jjm901, jmswms, jobren4, jordan, Juan.Cortes, Justbryguy, ken0042, Kevin-and-Julie, kixonrt66, KKapa, KoolAide, KyDan, lacroixyvon, ldmcmahan, lesameinze, LFugate, LuckyMcBRIDE, Maddog378, martin73, mbfree66, melbornj, mike54, Mrgary, mtibod1955, NanaKaren, NINA, Nursx2, ohiobill, Old car, Pa-cj5, Papa Roo, pgordemer, pg_rider, pmsherman, Poppy Bill, pryner, punkaccountant, Puyallup, radurecka, rbrandon, realebill, Redheaded blue tick, Retired63, rickthelen, RJHuser, Sailfish Bret, samiller, savdog, Scriggs1, SDENN4281, shavard, sideout1961, silverwing, SimchaSabre, skullskidr, snjparham, Snowsail, southernsky, sphinx, steeleshark2, Tee, Test Account, thom01, tmmar, travyp, treadwelll, Triguy, trudinator, True Believer, tshayn, tsmcmillen, TTNewbees, T_LMurphy, UPGRADER, Vette4trcr, vlite2011, wellcoman, whj77372, Wildcat Chris, win, y01lxb, yworrydog
Most users ever online was 944, 03-04-2012 at 01:27 PM.
Close [X]
