Flybob is correct. On mine, a 2016, crawl under and it is an directly aft of the battery disconnect you will see 2 fuse holders( green) with plug in fuse. Likely one is blown. FYI there is also a silver rectangular circuit breaker with an inconspicuous black button on the side that some times pops. Good opportunity to check your frame grounds, they do get corroded.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
