Forest River Forums
Sunline User Photos
Old 07-07-2010, 05:32 PM   #1
AKA KE2DX
Don and Elaine's Avatar
Slide out problem
I have a Flagstaff 831 FKBSS with 2 slides. In a rush to open the slides after a recent trip, I tried to open the main living room slide but after it would barely move, I found that I forgot to remove the travel bars. After removeing the bars, I then tried to operate the slide but nothing as if there is no power to the slide. I checked the fuse panel and circuit breakers but did not find anything that pertains to the slide and all fuses and breakers are OK. The rear slide works as always. Can anyone tell me if there is a reset button somewhere on the motor or elsewhere or did I burn out the motor? Thank you in advance for any help...Don
2008 Dodge Ram 4X4 Quad cab LB 2500 Cummings 6.7L Turbo Diesel /3:73 Posi Rear / Flagstaff 831FKBSS
Don and Elaine is offline   Reply With Quote
Old 07-07-2010, 06:25 PM   #2
Location: Jacksonville Florida - Home of the Jaguars !!!!
Hi Don, On Flagstaff slideouts, there is a green fuse holderone for each slide) with a 30 amp fuse inside. Look underneath on the frame at the tongue area- you'll see wires there along the inner frame, and you should spot the inline fuses there. I blew my main slide out fuse, and searched for it until I found the little bugger!! This should put you back in business. Randy
'08 V-lite Flagstaff 30WRLS
K&N series 77 intake, Hellwig pro series helper spgs.
'04 Durango Limited Hemi, '72 Mach One 351 cj
Old 07-10-2010, 07:25 AM   #3
AKA KE2DX
Thank You
Thank you Randy, your reply was right on the money. I was able to track the wire and locate the 30 amp fuse. Yes, It was blown but I always carry extra fuses of various types so I was good to go. Again, Thank you for your help!...Don
Old 07-24-2010, 12:29 PM   #4
baldy's Avatar
my fuse blows if i leave it in but otherwise the slide works fine. i have 13.68 volts (trickle charge voltage at my fuse) is this normal? does this circuit serve any other purpose? anyone with a schematic of the electrical systems?
baldy
baldy is offline   Reply With Quote
Old 04-10-2011, 01:31 PM   #5
I have a 2002 forrest river cardinal my slides ar beeping and wont come in?
ribbons is offline   Reply With Quote
Old 04-11-2011, 12:24 PM   #6
not sure how this works, but here goes...we have a sandpiper 2006 5th wheel, and it, too will not slide out. is the fuse solution the same for this one? motor ratchets, but just won't move.
catschaefer is offline   Reply With Quote
Old 04-11-2011, 01:41 PM   #7
What do you mean by "motor ratchets"? If the motor is recieving power to make it move at all, then the fuse isn't the problem . If the slide is a "superslide", meaning a large slide, it uses 2 motors to operate it. If both motors are trying to turn, then chances are you have something in a bind. If one works but not the other, it will quickly get in a bind, and not work. Mine got in a binding problem because the carpeting came loose at the leading edge, and basically rolled itself up under the slide "box", lifting the whole thing up and stopping any farther movement out. I could move it back in, and it worked. Had to re- tack the carpeting, and it was good. One other thing...I'm not sure whether or not Sandpiper's have electric (motorized) slide outs. or hydraulic fluid operated. If hydro powered, some of this may not apply to yours. Good Luck, Randy
Old 04-11-2011, 04:00 PM   #8
Unhappy slide out won't move
thanks for the hint... but the slide is for the dining/living area, so don't know if it is a superslide. by ratcheting I mean it sounds like it's supposed to work, either in or out but won't move. whole camper is 30 ft if that helps. was going to take to dealer, but with weekend coming would rather be camping, and they said it would be 2 weeks before they could get to it!!!!
Old 04-11-2011, 11:28 PM   #9
Sorry catschaefer! To clarify, a Superslide is generally a large slide out, 8 ft. or wider. Also, I would send an assistant under the unit to see what happens when the slide out button is pushed. On mine, you can see the 2 motors and the bars with teeth on them that the motor gears mesh with to operate the slide out room. But, as I said previously, yours MAY be hydraulic; in which case fluid and pumps/hoses are used to operate the slide out bars, as many 5er's are. Just need to crawl under and see for yourself which system you have. Good Luck, Randy
Old 04-12-2011, 07:22 AM   #10
Lou Amadio
herk7769's Avatar
I think you are talking about the gears when you talk about 2 motors.
There is only ONE motor on each slide and a transfer bar between the two nylon gears that run the slide in and out on the large toothed "RACK" that holds the slide.
To "save the motor" when the slide does not move and you try to run the motor anyway (this happens when you reach full travel in or out) the nylon wheels "HOP" on the toothed rack. That is the "ratcheting" sound you hear. Do this enough and the nylon teeth wear or break off.
Worn enough, the slide will not move. The nylon gear teeth will just grind away in one spot making that ratcheting noise.
What can also cause that ratcheting sound is:
Stuck slide seals:
1) Ice on seal "glues" slide to wall.
2) tree sap on open seal "glues" slide to wall when closed
Obstruction:
1) Cabinet door open and catching slide trim
2) Slide Travel bar installed
3) Forgot ice chest under slide when closing
4) Hit power/water pedestal with slide and keep trying to open
5) Item jammed between slide trim and wall when opening
Let that slide ratchet long enough with any of these conditions and you will have rounded or broken nylon gear teeth.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 4)
herk7769 is offline   Reply With Quote
» Online Users: 665
149 members and 516 guests
1l243, 4bnabird, alphadog99, anitag, armye7, autorot8, Bearcat55, bidesheng, BigKidzFun, Bigmatt, BigR, Bingo71, BlakeB, bob34787, BonnieSeip, bowtang2001, bush, bwbarnes, Cafjackracing, Cairdeas2111, camping4us, campkng, Capsfloyd, carsonizik3, Cascade Bob, cdbus, cnkc, CRZ, Dakota EV, dashonthedash, davidjb, daw592, ddemme, depo, Derekcan, dkwalsh, dnaraG_1M, doc73, donh, doosterhouse, Drmstx62, DTingle, EL99jl, emljr, extremebike, f1100turbo, Falcon35, feerobk, forthefunofit, fpdeod, FreedomTracker, Gary Bridges, gator14, gbowman143, gmw65, growe, Hamblen, HemiCab, Hilgy, Interface Admin, itech, Itsthetwoofus, Janet H, jar3316, jechst, JedinWI, jerrygallion, jjm901, jmswms, jobren4, jordan, Juan.Cortes, Justbryguy, ken0042, Kevin-and-Julie, kixonrt66, KKapa, KoolAide, KyDan, lacroixyvon, ldmcmahan, lesameinze, LFugate, LuckyMcBRIDE, Maddog378, martin73, MayorBobK, mbfree66, melbornj, mike54, Mrgary, mtibod1955, NanaKaren, NINA, Nursx2, ohiobill, Old car, Pa-cj5, Papa Roo, pgordemer, pg_rider, pmsherman, Poppy Bill, pryner, punkaccountant, Puyallup, radurecka, rbrandon, realebill, Redheaded blue tick, Retired63, rickthelen, RJHuser, Sailfish Bret, samiller, savdog, Scriggs1, SDENN4281, shavard, sideout1961, silverwing, SimchaSabre, skullskidr, Snowsail, southernsky, sphinx, steeleshark2, Tee, Test Account, thom01, tmmar, travyp, treadwelll, Triguy, trudinator, True Believer, tshayn, tsmcmillen, TTNewbees, T_LMurphy, UPGRADER, Vette4trcr, vlite2011, wellcoman, whj77372, Wildcat Chris, win, y01lxb, yworrydog
Most users ever online was 944, 03-04-2012 at 01:27 PM.
Close [X]
