12-26-2011, 07:53 PM
Slide out question
I have a 2011 Wildwood and the slide out will sometimes get stuck when running it in. Its like the weather seal is sticking. Is there something to lubricate these?
Daniel
12-26-2011, 08:42 PM
I pretty sure they sell a spray.
2011 Solera
Work 28 and 28 around the world.
Camp every chance we get.
12-26-2011, 09:05 PM
Anacortesians
Daniel:
If it's a long vertical blade seal either on the underside or topside of the slide-out, you can hand-rub powdered graphite onto the surface of the slide, or use a srpay-on molybdenum disulphide luricant that dries.
I have an on-going problem with the underside seal on the bedroom of my MH and the moly spray is one of this off-season's projects. I'll be doing it to both top and bottom blade seals on both slides.
Frank and Eileen
1 Labrador - Bailey (M) now 8. RIP Cocoa 06 Sep 11.
02 Georgetown 325, F53 V10
12-26-2011, 09:24 PM
If it attracts dirt or can attract dirt, avoid it like the plague. There are many dry lube available for rubber seals. Personally I use ProtectAll to both clean and lubricate my seals. I do use a dry type lube on all of the slide mechanism I can see or reach.
12-27-2011, 06:56 AM
Lou Amadio
Totally agree. Dry lube on anything metal that moves. Stuff collects dirt and mud as it is, no sense "welcoming it aboard!"
Silicon spray on anything else.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 4)
12-27-2011, 03:55 PM
why wouldn't you use silicon ? or does it attract dirt /
12-27-2011, 04:22 PM
Lou Amadio
Pure silicon spray will not protect or lubricate the metal of the steps, slide bars, and rollers for more than one or two activations. Dry lube stays on the surface of the metal but does not attract dirt.
Silicon works great for lock mechanisms, hinges, drawer glides, and slide seals.
12-28-2011, 08:52 AM
Dallas Texas
Lou - Don,
What dry lube have you found to be affective? I hear a lot about dry lubes specifically for the trailer market but my guess is others will work fine.
Cheers
2003 Cardinal 33CKT
2006 Ford SD F250 CC 4WD
2001 Coleman Santa Fe (to be sold)
1984 Honda Magna V65
1963 M50 Harley Davisdon
12-28-2011, 09:34 AM
Lou Amadio
Just Google "Dry Lube for Slides" and you will get a number of good hits from Discounters like RVWholesalers. Any "Dry Lube" in a spray can will work. NOT Oil or Silicon for slide mechanisms though.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 660 |
| 148 members and 512 guests |
| 1l243, 4bnabird, alphadog99, anitag, armye7, autorot8, Bearcat55, bidesheng, BigKidzFun, Bigmatt, BigR, Bingo71, BlakeB, bob34787, BonnieSeip, bowtang2001, bush, bwbarnes, Cafjackracing, Cairdeas2111, camping4us, campkng, Capsfloyd, carsonizik3, Cascade Bob, cdbus, cnkc, CRZ, Dakota EV, dashonthedash, davidjb, daw592, ddemme, depo, Derekcan, djorgensen3, dkwalsh, dnaraG_1M, doc73, donh, doosterhouse, Drmstx62, DTingle, EL99jl, emljr, extremebike, f1100turbo, Falcon35, feerobk, forthefunofit, fpdeod, FreedomTracker, gator14, gbowman143, gmw65, growe, Hamblen, HemiCab, Hilgy, Interface Admin, itech, Itsthetwoofus, Janet H, jar3316, jechst, JedinWI, jerrygallion, jjm901, jmswms, jobren4, jordan, Justbryguy, ken0042, Kevin-and-Julie, kixonrt66, KKapa, KoolAide, KyDan, lacroixyvon, ldmcmahan, lesameinze, LFugate, LuckyMcBRIDE, Maddog378, martin73, MayorBobK, mbfree66, melbornj, mike54, Mrgary, mtibod1955, NanaKaren, NINA, Nursx2, ohiobill, Old car, Pa-cj5, Papa Roo, Paul Short, pgordemer, pg_rider, pmsherman, Poppy Bill, pryner, punkaccountant, Puyallup, radurecka, rbrandon, realebill, Redheaded blue tick, Retired63, rickthelen, RJHuser, Sailfish Bret, samiller, savdog, Scriggs1, SDENN4281, shavard, sideout1961, silverwing, SimchaSabre, skullskidr, Snowsail, southernsky, sphinx, steeleshark2, Tee, Test Account, thom01, tmmar, travyp, treadwelll, Triguy, trudinator, True Believer, tshayn, TTNewbees, T_LMurphy, UPGRADER, Vette4trcr, vlite2011, wellcoman, whj77372, Wildcat Chris, win, y01lxb, yworrydog |
| Most users ever online was 944, 03-04-2012 at 01:27 PM. |
