Originally Posted by grumpy0374
Most of your better aftermarket spray bottles have an adjustable tip. Ones I use shoots either a spray or a very narrow stream.
When I treat my top seals, I just use the stream and shoot it along the seal.
Another way, just wire tie an old sock to a long dowel. spray it and run it along the seal.
Grumpy
x2 on the dowel rod/broom handle etc. is probably the easier setup to make for most.
I ended up making this one morning, It's wrapped with a 6 x 9 gauze pad then tie wrapped that I saturate with the 303, I can slip it under the seal and drag it back across the top side a couple times and from both ends of the 12' slide. I do have slide toppers in place. I don't spray the 303 on directly but use a rag for sides and bottom seals
Grumpy, was that you that suggested the Cowles body side moulding strip to get the seals to fold out at the tops of the slides? If it was, you were right on!
