Originally Posted by Dylan14335
Hello I have a 2012 lacrosse 318 bhs and the slide outs will not work unless my battery is charged even though it is plugged in to shore power.
Your slide outs use more amps than the converter can supply so it needs the extra amperage the battery can supply.
But shouldn't it charge my battery once plugged into shore power
Yes, but only if the reverse polarity fuses are good, the battery disconnect switch is on, and the breaker between the battery and trailer is not tripped.
Why does my power awning still work with battery unhooked but plugged into shore power
Your power awning uses considerable less amperage to run than the slide motor.
