Old 10-28-2010, 11:10 AM   #1
slides and jacks
bedroom slide out won't come back. Level jacks won't go down. Slide buttons make noise when pushed but no movement.
Georgetown SE 340
grady is offline   Reply With Quote
Old 10-28-2010, 02:41 PM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
Georgetown SE 340
Is the parking brake set? Jacks won't move otherwise.
Is the motorhome running or key turned to on position? Slides won't move.
How's the strength of your coach battery/batteries?
There is a resettable breaker under the steps for the slides/leveler.
to the Forums. Hopefully this solves your problems. Let us know the outcome, Charlie.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 11-09-2010, 01:23 PM   #3
Batteries showing fully charged. cleaned contacts. Did everything else. no workie. With ignition off pump will make noise when button pushed.
Old 11-09-2010, 06:31 PM   #4
Is the hydraulic fluid reservoir at or near 1/2" from the fill cap. Had a similiar problem and the fluid was too low.
tetsurvivor is offline   Reply With Quote
Old 11-10-2010, 11:18 AM   #5
Thanks. We found the problem. The switch for the pump motor (Black right in front of the pump) was bad. Text by someone inside working the switch and someone at the pump crosing to the left or right post from the power. Red to black.
jacks, pump, slide out, georgetown
