Old 09-03-2015, 08:07 PM   #1
Soft Spot in Floor
I seem to have developed soft spots in the floor in the kitchen. Is this normal?
Angel is offline   Reply With Quote
Old 09-03-2015, 08:27 PM   #2
KenHwy61's Avatar
It is not likely normal although I have heard of campers built with flimsy flooring. More probably is water damage rotting your floor. Posting what model camper you have will give owners of the same a chance to share their opinion.
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
Old 09-03-2015, 08:30 PM   #3
BooBoo23's Avatar
No it is not normal. Give us more information. What kind of RV do you have, make, model, year. You probably have a water leak problem. Since you say in the kitchen area did you check any plumbing fittings for possible slow leaks or as someone on another thread mentioned a cracked fitting on the water heater. Do some detective work.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is offline   Reply With Quote
Old 09-03-2015, 08:59 PM   #4
It's a 2013 Columbus 5th wheel 370fl. I can't seem to find any leaks, but will do some more investigating. Thanks for the responses.
Old 09-08-2015, 12:54 PM   #5
thebrakeman's Avatar
Need to find the source, and stop the leak before you bother with any repair. Nothing worse than fixing something in dry conditions, only for it to happen again from the same problem.
Being a 5th wheel, it likely has a joist-floor, which can likely be repaired in the affected area. Those with ultralites (including laminated floors without joists) are much worse-off when soft spots surface. Ask me how I know.
thebrakeman is offline   Reply With Quote
