Old 11-01-2010, 05:56 PM   #1
Question Some kind of sensor in bedroom ceiling
I recently purchased a 2005 Forest River 29RLBS and their is what looks like some kind of a sensor on the ceiling in the bedroom. Does anyone know what this is? It is located closer to the curbside of the coach. Thanks
Rick C is offline   Reply With Quote
Old 11-01-2010, 09:59 PM   #2
Is it round, and have a "test" button? Does it protrude from the ceiling? Does it have arrows on it pointing which way to twist to remove? I'm guessing it is a fire/smoke detector. Not sure when, but all RV's are required to have them in all bedrooms I think. Someone chime in if my thinking is wrong.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 11-01-2010, 10:21 PM   #3
Villa Estate 392FLFB
The_Stuff's Avatar
one in my bedroom is the CO2 detector
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 11-01-2010, 11:06 PM   #4
i agree with windrider its a smoke detector CO2 dertector are usually closer to the floor
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 11-01-2010, 11:30 PM   #5
CO2 detectors in newer, (not sure when it started) trailers are required in the stove/furnace area. Never seen on in a bedroom, but that doesn't mean they aren't there.
LadyWindrider
Old 11-02-2010, 12:00 AM   #6
The_Stuff's Avatar
yup CO2 in bedroom, smoke detector in corner of kitchen and LP gas detector is on the wall near floor in kitchen area.
Old 11-02-2010, 04:09 AM   #7
cardinal4fun's Avatar
My co2 is located in the bedroom area and the smoke is located closer to the kitchen area. Thus yours should be co2
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
Old 11-02-2010, 05:17 AM   #8
MrT
MrT's Avatar
Or it could be a carbon MONoxide (CO) detector.
2017 Cedar Creek 38CK Hathaway Edition
2015 Ford F-350 6.7 CC 4x4
B&W RVK3300
Full-timing since 5/2/2016. Roam Sweet Home.
FROG Int'l Rallies: 2012-2017
MrT is offline   Reply With Quote
Old 11-02-2010, 05:20 AM   #9
Carbon MONoxide, CO detector. There is very little hazard from moderate amounts of CO2, Carbon Dioxide. CO2 is in our carbonated drinks. I'm sorry to make this correction, but I have to hear our fire dispatchers make this mistake time and time again. CO is A KILLER! Whether your TT, 5'r, or coach came with a CO detector, MAKE SURE YOU HAVE AN OPERATING ONE! The hot water heater can produce enough CO to kill you if not exhausting correctly, and it can have been jarred just a little bit. CO is colorless, oderless and is the same weight as air so it doesn't matter where you put the CO detector. Just make sure it is rated for an RV, it will say it on the box. They are sensitive electronics devices and some can be damaged by jarring. They also have a life. I think that the sensors are going about 8 years, REPLACE EVERY 5 YEARS. I lost a firefighter buddy I went to high school with in a fire, and it was found that he had CO poisoning from home. His hot water heater in his house vent was not correct. The fire he was fighting was enough to put him over the lethal level. His death saved his fiances life by allowing her to get treatment in time. CO affects the young and the elderly first and severe! Please make sure you CO detectors and your smoke detectors are in working order and CHANGE THE BATTERIES at least every spring. If you're a full timer, at the time change (this coming weekend). That is my safety topic of the day!
Kirk out!
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
Old 11-02-2010, 06:24 AM   #10
Dodge Guy's Avatar
I would certainly hope that the poster knows what a Carbon Monoxide Detector is. but I guess nothing would surprise me.
How about a picture?
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 11-02-2010, 10:09 AM   #11
tmmar's Avatar
Not sure what your camper is like but does it have 2 air conditioners? If so, it could be a sensor to control the A/C unit that takes care of the bedroom area. It is a sensor that will tell when the room reaches the temperature the thermostat is set for.
Tom and Margaret
2014 Berkshire 390bh-60
Old 11-03-2010, 06:16 PM   #12
Toy-aholic
it's a camera
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
bed
