Old 05-19-2016, 09:03 AM   #1
Lilredram's Avatar
Question squeaky floor????
Hi all
Floor between bedroom and hall squeaks is this a problem? Can any thing be done to fix it. Doesn't bother me but DW is complaining Any help would be greatly appreciated.
Thanks RonG
__________________________________________________ ____
2017 CC Silverback 29RE / UVW (dry wgh't.)=10,705 lb
Pin wgh't.=1,985 lb / GVWR=13,985 lb
2016 Ram Delmonico Red 2500 CC 4x4 6.7L Cummins
with rear air suspension 68RFE 6spd Auto 3:42 axle
Gvwr=10,000 lb GCWR=23,300 lb payload
Lilredram is offline   Reply With Quote
Old 05-19-2016, 06:37 PM   #2
arpipeliner's Avatar
Mine has and hasn't when on a concrete slab. Makes me think it is not perfect level. I have seen the board flex on the support in the basement when walked on. Heard some put wood shims in to stop noise. I hope to have auto level and hope that will solve the problem.
arpipeliner is offline   Reply With Quote
Old 05-24-2016, 11:54 AM   #3
On our previous travel trailer the floor squeaked. There was no moisture or structural damage. It seems like they didn't put enough screws from the factory screwing the subfloor down and it would ride up and down as you walked on it causing it to squeak/pop. I found a kit that allowed you to countersink screws and snap the screw heads off under the linoleum flooring. It worked like a charm. I can't remember the name of the kit I used when I get back home on Friday I can send you a picture of the kit I used.
Nosedive is offline   Reply With Quote
