Old 08-05-2012, 11:44 PM   #1
Location: No longer own a Forest River product, but enjoy the info on this site
stabilizer - any new ideas
the first night out in the new camper resulted in CARGAGE -- we hit a good sized rock with the stabilizer jack and "V" shaped scrape bar. Any thoughts on a low profile stabilizer jack that would work as a replacement?
teamgl is offline   Reply With Quote
Old 08-06-2012, 09:24 PM   #2
vasnipe's Avatar
Replacement jacks
teamgl,
You could get a pair of these at Camping World or maybe Wally World.
Aluminum Stack Jacks - Product - Camping World
Or one of these scissor jacks at Camping World, depending on what height you need.
Search - stabilizing jacks - Camping World
Chris in Virginia
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is offline   Reply With Quote
Old 08-06-2012, 09:33 PM   #3
Straighten what you have and remove the tube spacer would give you some more clearance.
Old 08-06-2012, 09:48 PM   #4
Straighten the scrape bar. It looks like a 1 inch piece of square tubing welded to the frame to have a place to screw the jack to. Cut most of the tubing away, leaving the top portion that is welded to the frame. If the jack is damaged, get a new jack and weld it to the remaining tubing. That way you aren't welding on the frame to void your warranty, and it will raise your jack about an inch.
Option 2, call the insurance company, sounds like road hazard to me.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 08-06-2012, 10:16 PM   #5
The scrape bar should be reinforced with a pc of 1/2" bar stock along it's full length. Remove the tube for the jack and bolt the jack to the frame itself.
Old 08-06-2012, 10:27 PM   #6
Thanks for the info. Looks like its just tack welded to the frame and can use the the small grinder on the dremmel drill to cut loose the welds -- or perhaps an hack saw.
That stuff hangs too low anyway.
Old 08-06-2012, 10:34 PM   #7
Don't think a Dremmel will do the job, too small. A 4" or 4-4/2" grinder with a thin cut off wheel would work very well. Those 1/4" straps are too thin to do the job intended which is to protect the undercarriage from scrapping on the road. They should be reinforced by add at least 3/8" or 1/2" bar stock as about 4 scrapes on concrete over about a foot, they will be worn out.
