Old 07-20-2016, 11:42 AM   #1
Stabilizer ground contact pressure
Does anyone have a guess as to how much down force, or pressure, scissor style stabilizers might have when properly deployed? I'm getting tired of stacking pieces of wood under them so they have a wider stance, rather than have them extend way down to the ground. I'm thinking of a lightweight plywood 'box' about the size of a 1 foot cube. Obviously I'll have an internal x brace to carry the pressure. Just not sure how robust to make them. Thanks!
David and Vicki
6 year old Springer rescues Sydney and Piper
2014 GMC Denali 3500HD Dually Crew Cab Duramax/Allison stock "Doug"
2016 Dutchmen Denali 287RE "The Dog House"
Eaz Lift WDH 1400# w/ Blue Ox 2 1/2" trunion
EezRV TPMS
Springerdad is offline   Reply With Quote
Old 07-20-2016, 11:53 AM   #2
JustB_Rad's Avatar
I'm guessing enough that a hollow plywood box is not enough to support it. Remember, that pad on the bottom of the stabilizer is only what? 4x6? Its still gotta be in the hundreds of pounds.
I just took a 4x6 (Not treated) and cut it into 11" chunks and painted them gray with outdoor paint. They're easy to clean off, easy to grab and easy to store. They're light enough too. I stack 2 under each jack.
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
(2014) Nights Camped - 16 in 6 trips (2015) Nights Camped - 20 in 6 trips
(2016) Nights Camped - 21 in 7 trips
(2017) at least 23 Nights Planned in at least 6 trips!
JustB_Rad is offline   Reply With Quote
Old 07-21-2016, 07:36 AM   #3
Originally Posted by JustB_Rad View Post
I'm guessing enough that a hollow plywood box is not enough to support it. Remember, that pad on the bottom of the stabilizer is only what? 4x6? Its still gotta be in the hundreds of pounds..
That's why I'm planning on a vertical X brace inside.
Old 07-21-2016, 08:07 AM   #4
jeff
jeff64's Avatar
I suppose if you really had to know how much force is applied, you could put a bathroom scale under the pad and deploy it on a solid surface. Know scales capacity first so you don't overcook the scale
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 07-21-2016, 08:14 AM   #5
JustB_Rad's Avatar
I guess that's why I suggested what I do...by the time you build a plywood box and put an x-brace on the inside, it will weigh more than the 5lb blocks I suggested.
Old 07-21-2016, 08:30 AM   #6
You are probably right! But then, I wouldn't have to stack anything. Lol.
Old 07-21-2016, 08:37 AM   #7
JustB_Rad's Avatar
Honestly went through all that stuff in my head when I did mine. I was going to put hinges and clasps to make them easier to carry and blah blah blah.....and after using these blocks this way for 2 years now, it's just fine. It's simple, reasonably priced, looks nice and does the job. The best part is, if I end up on a site with a slope, I can use 1 block in the back and 3 in the front, or vice versa. It's still interchangeable. I store them in my slide out storage compartment, carry one block in each hand to each stabilizer and I'm done. IMO its a lot easier than trying to stack 2x6's or 2x8's too.
Old 07-24-2016, 11:34 AM   #8
When properly deployed there shouldn't be much downward pressure on the stabilizers - static case and nobody in the RV. That can increase up to more than two people's weight if they are on the back bed and the stabilizer is in front of the bed. How much of the weight is being transferred to the axles by the frame would be the question.
Fred W
Old 07-24-2016, 11:54 AM   #9
Stabilizers are not jacks. A properly glued and screwed 1/2" plywood open-ended box will have more than enough strength to provide a solid base for the stabs, even without an x-brace, plus provide storage when not in use. OTOH, a couple of 6x blocks would work, too.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 07-24-2016, 12:48 PM   #10
I don't have scissor jacks, but cut some 2X12 down in 12 inch sections and screwed them together. Then attached a metal handle to make them easier to move.
tkarper14 is online now   Reply With Quote
pressure
