Old 04-24-2016, 08:43 PM   #1
Limey's Avatar
Cool Stabilizing Jacks
If you have motorized stabilizers, you have them in the "down" position & the motor takes a "dump", how to you retract them ? They are on a Rockwood TT.
Limey is offline   Reply With Quote
Old 04-24-2016, 09:26 PM   #2
Scubanut's Avatar
If you have your manual it should give you instructions how to manually retract them. On my trailer if I recall correctly was to disconnect power going to the affected stabilizer. Then manually crank them up with the provided wrench.
2012 F150 FX4 Crew 5.0 3.73
2012Coachman Freedom Express 292BHDS (outdoor Kitchen)
Scubanut is offline   Reply With Quote
Old 04-24-2016, 10:07 PM   #3
raspivey's Avatar
If they're like mine, they're just motors attached to the jack screws on one end. You just put the crank on the other side and roll them up and down. If the motor seizes up, I think they're only held on by four mount bolts.
Old 04-24-2016, 10:30 PM   #4
Correct,and if you remove the motor you will be surprised how Quick you can crank the Stab Up and Down! Youroo!!
youroo is online now   Reply With Quote
Old 04-26-2016, 04:46 PM   #5
Limey's Avatar
Thanks for the responses.
jacks
