Old 10-06-2017, 02:15 PM   #1
Stained Awning
Just bought a used 2016 Wildcat. The awning has been rolled up damp and dirty. Any suggestions on cleaning. Tried dish washing liquid. Helped some. The stain is on the under side which is white. Looks like it came through from the top side
WildcatAR is offline   Reply With Quote
Old 10-06-2017, 02:26 PM   #2
Spray with X14, let soak for 10 mins, spray again, roll up for 30 mins, unroll and wash with simple green and 1/4 cup of bleach in regular car wash bucket with telescoping pole like you use to wash RV with. Rinse really good. Try to keep sides of RV wet so wash solution does not remove wax.
Decon Blue is offline   Reply With Quote
Old 10-06-2017, 02:28 PM   #3
I'll give it a try. Thank you!
Old 10-08-2017, 03:09 PM   #4
Canadian Member
Mr. Clean Magic Erasers work well for me.
Old 10-20-2017, 06:43 PM   #5
gooiebob's Avatar
I use the wife's wet Swiffer floor cleaners.
2019 Della Terra 29k2s
2014 Toyota Tundra 5.7
gooiebob is offline   Reply With Quote
Old 10-20-2017, 07:06 PM   #6
I mix dawn/bleach/water in a sprayer. Spray on awning top and bottom roll up for 20 min the open up and rinse off works for me every time.
2017 6.7 CC Lariat
2018 CC 38EL Champagne
Harleyhop is offline   Reply With Quote
Old 10-21-2017, 07:24 AM   #7
Second the Harleyhop method except I use exterior house wash from Lowes a little more gentle on the outside of your unit and also contains butyl rubber helps with black streaks. I use this mixture to wash roof also.
Rich5117 is offline   Reply With Quote
Old 10-21-2017, 07:30 AM   #8
I have issues with water getting between the "rolls" of the awning when it is rolled up. I clean it up really nice, then next think I know it has mildew streaks from both ends where water ran between the rolls during a rain shower. I really can't seem to get the awning to roll up any tighter than it does. I guess if I did not have it level I would only get the issue at one end of the other.
Anyone ever had this issue?
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Asrabbit is offline   Reply With Quote
Old 10-21-2017, 08:08 AM   #9
Canadian Member
It’s completely normal to have moisture get into the rolled up awning. Can’t do anything about it .
Old 10-21-2017, 08:14 AM   #10
Kasual Kamper
What ratios do you use?
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 10-21-2017, 09:15 AM   #11
Hugeez's Avatar
Mean Green mold and mildew remover. Spray down the awning with water. Spray on the Mean Green, I sprayed the entire underside of the awning. Roll the awning up and leave for 20-30 minutes. Open awning up and completely rinse off with water. We found the Mean Green at Dollar General.
2018 PUMA 31 BHSS
2017 RAM 2500 LARAMIE 6.4 HEMI 4X4
E2 WDH
Troy, Josie and our 2 K9 co-pilots Breck and Maggie
USN 86-92
3 nights camped so far in 2020
Hugeez is offline   Reply With Quote
Old 10-21-2017, 10:32 AM   #12
Summer2Go
Summer2Go's Avatar
I used a bleach component spray and a soft car wash head on a long wand. The stuff drips off and bleaches my clothes evertime, so watch out!
Summer2Go is offline   Reply With Quote
Old 10-21-2017, 10:55 AM   #13
Hugeez's Avatar
Good point!!! Forgot to mention that!!! Don’t wear anything nice.
2018 PUMA 31 BHSS
E2 WDH
USN 86-92
Old 01-03-2018, 01:45 PM   #14
I use the L A Awesome cleaner you can get at dollar store! Spray it on and roll it up for 20 minutes. Roll it out and power wash! Yes
gmann32 is offline   Reply With Quote
Old 01-06-2018, 02:01 PM   #15
joforbess's Avatar
Stained Awning
Has anyone ever tried this option to keep water out of the awning?
http://www.doityourselfrv.com/make-d...protectors-rv/
2012 Ford F150
2014 Salem 27RKSS
joforbess is offline   Reply With Quote
Old 01-07-2018, 07:05 PM   #16
lugoismad's Avatar
You want a mildew remover. Bleach works just fine. Spray it down with bleach then hose it off. If its really bad, you might need to scrub.
lugoismad is offline   Reply With Quote
Old 01-07-2018, 07:22 PM   #17
L A Awesome is .......just..........wait for it...........AWESOME!:signha vefun:
Best $1 you will ever spend.
Old 01-07-2018, 07:41 PM   #18
crunchman12001's Avatar
A member here did a great review of Mold Armor which prompted me to give it a try. This stuff works wonders without scrubbing. You can buy it at Home Depot.
http://www.moldarmor.com/product-fam...stain-remover/
2015 F-250 FX4
Old 01-17-2018, 02:26 PM   #19
Half bleach half water in a spray bottle works every time
captken is offline   Reply With Quote
Old 01-17-2018, 02:50 PM   #20
I gave my awning a good cleaning and it seems to have a hard time rolling up.
Like the motor is going out or just struggling to roll it up. Seems like before it rolled up with a little more speed. I checked for a lube point, doesn't seem to be one.
Any ideas?
Thanks, RMc
Wheels Down is offline   Reply With Quote
awning
