Old 04-23-2012, 07:56 PM   #1
Dennis and Julie's Avatar
Steadyfast stabilizers
We have been considering the Steadyfast Stabilizers for out Flagstaff 30wfkss but looking underneath the whole underside is enclosed including the frame. Has anyone done this and how do you access the frame?
Dennis and Julie
2018 Wildcat 28SGX
2013 Chevy Silverado 2500HD
2012 Chevy Silverado 2500HD
Dennis and Julie is offline   Reply With Quote
Old 04-23-2012, 08:05 PM   #2
The frame is directly above the joint covered by the black strip. The frame has a 1x2 pc of wood attached to the lower flange of the I beam frame. I drilled thru the wood and tapped into the lower frame flange.
Old 04-23-2012, 08:05 PM   #3
TURBS's Avatar
You can attach to the frame leaving the skirting in place .
Mine is also fully enclosed. except where the propane tank mount is .
Name:	2011-09-05 17.50.21.jpg
Name:	2012-03-06 16.41.29.jpg
Name:	2012-03-06 16.40.23.jpg
Old 04-23-2012, 08:07 PM   #4
TURBS's Avatar
If you look close to the last pic I scribed a line where the frame was so I know where to attach mount .
The only thing you have to be careful with is the frame is an I beam so you need to be on either side of I so you can drill and bolt .
By the way the stabilizers are a great investment !
