Old 09-03-2016, 04:51 AM   #1
Travelers 500,000+
Step bolt missing, need to replace
We have the three step sets. The bolt to the 2nd step is missing. Went to RV dealer and they said company won't sell replacement part. Any idea what type of bolt to buy at hardware store?
Attached are the type of steps and the bolt I'm talking about.
TIA!
ID:	119276   Click image for larger version
ID:	119277   Click image for larger version
Mary B and Ann S
Known as the Mermaids
(Retired )
Michigan Campers/Travelers
Days camped in 2015 145
Murmaids is offline   Reply With Quote
Old 09-03-2016, 05:16 AM   #2
Witch Doctor's Avatar
I just had the same problem, The top rivet I guess I would call it sheared off, I just went to ace and bought a new bolt and nut and replaced it, it works fine I think I bought stainless steel. Took the old one with me to get the correct dimension. I just put the nut on the inside for clearance sake.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 09-03-2016, 07:30 AM   #3
Witch Dr is correct,what you have pictured is a "Rivet" they require a Special Machine or Tool to install! If you go to a "Fastenal Store" they can supply the fastener you need! Just using a Bolt,washers and lock nut is not the Best repair! Youroo!!
youroo is online now   Reply With Quote
Old 09-03-2016, 08:00 AM   #4
It will work unless you need a crane like Youroo to get picked up. By the way Youroo what is the difference, it couldn't be weaker, I was going to replace all mine, there all starting to rust out. Hate to fall like I almost did when mine broke, and I only way 99 lbs dripping wet..
Old 09-03-2016, 08:02 AM   #5
...Just using a Bolt,washers and lock nut is not the Best repair! Youroo!!
Contrary to Youroo's statement, Replace all of the rivets with Gr 8 bolts, washers and nyloc nuts.
Old 09-03-2016, 08:22 AM   #6
If your going to Quote Me use the whole thing not just Part! You must be a part time Political Writer? Youroo!!
Old 09-03-2016, 08:24 AM   #7
GreenImp's Avatar
Send a message via MSN to GreenImp
Do like OC says and the stairs will forever be as solid as they were the first one or two times you used them (if you purchased the RV new).
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 09-03-2016, 08:31 AM   #8
The rest of your statement was ok, was just taking issue with "...Just using a Bolt,washers and lock nut is not the Best repair!"
Old 09-03-2016, 08:58 AM   #9
I think I'm going to replace all mine, forgot about using grade 8 bolts and nuts, they will last for ever, someone could get really hurt when they break off. Even a young person with good balance, and then you have me, my balance is getting worst as I age. People think I'm drunk but it's just a balance effect..
Old 09-03-2016, 09:17 AM   #10
OC is right, nyloc nuts on anything or any place where there is a nut on the trailer, inside or outside,..... don't trust regular nuts with LOCK washers
fella10 is online now   Reply With Quote
