Old 06-05-2011, 05:51 AM   #1
mike54's Avatar
Question stove quick connect
I bought a Explorer 2 Burner Propane Stove
Model No: EX60LW where do I get the quick connect for the stove so I can use the quick connect on my travel trailer?
Mike & Marsha
2011 Signature Ultra Lite 8319SS
2005 Dodge Ram 3500 5.9 cummins diesel
http://www.facebook.com/WestAllisSunshiners
mike54 is offline   Reply With Quote
Old 06-05-2011, 06:16 AM   #2
Stevea1956's Avatar
I called a local "fireplace and barbeque" store and they pointed me to a propane supply shop they use. I took some pictures of the RVQue gas line and the quick connect fitting that is on the trailer. They made me a gas line for my Coleman 2 burner stove and a "T" for the TT so I can use both the RVQue and Coleman at the same time.
Steve & Lauren
2011 Windjammer 3065W
2012 Ram 3500, 6.7 Cummins
Stevea1956 is offline   Reply With Quote
Old 06-11-2011, 08:34 AM   #3
Here is a web site I used to get quick connectors for the outside connection. I called them and they where able to get me everything I needed to connect a grill of my choice to the trailer gas system.
Fairview Fittings And Manufacturing
Good luck,
Patrick
PatrickCrotty is offline   Reply With Quote
Old 06-26-2011, 09:39 PM   #4
I want to use the hose coming out of my 2010 Freedom 1980 intended for the RVQue to instead provide gas to my weber babyq, any ideas on what I need?
Tom
d2tw4all is offline   Reply With Quote
Old 06-26-2011, 11:40 PM   #5
bikendan's Avatar
what's not being talked about is that the line that is for the RVQ or Sidekick Grill, is low-pressure.
almost every other type of grill and stove is high-pressure.
the only one i've found that works with low pressure, is the Camp Chef line of stoves.
Old 06-26-2011, 11:54 PM   #6
WestCoastRV'er's Avatar
Upgrading RV grill to infrared grill
Tom
I'm replacing my RV bbq grill with an infrared bbq grill and hoping I can use the same connector from my old RV bbq grill. I too want to get a t-connector so I can connect my coleman 2 burner stove. Tired of replacing the 1lb bottles.
As others have mentioned here, I will be taking it to a propane fitting company to build the extended hose and t-connector.
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 06-27-2011, 05:42 AM   #7
mike54's Avatar
what I did to hook up my Camp Chef 2 burner low pressure stove was take the quick connect female connector off the RVQ gas grill and took the regulator off the stove put the quick connector in place of the regulator now it connect to the hose on the camper
Mike & Marsha
Old 06-27-2011, 06:34 AM   #8
Fire Instructor's Avatar
Your Coleman stove works on high pressure. Any connevtion that you make beyond the RV primary regulator (at the propane cylinder) will be low pressure.
Get yourself an Amazon.com: extend a stay propane and a hose or two. The Extend-a-stay goes on one of your propane bottles, before the pressure regulator, and supplies high pressure propane to the stove.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
