Forest River Forums
Sunline User Photos
Old 11-13-2011, 05:26 PM   #1
strange problem - amber outside light
We have a Cherokee 28BH TT and am having a strange issue. the amber outside light CANNOT be turned off for some reason!!!........the dual switch panel inside the camper works the interior lights fine, and WAS turning the exterior(amber) light on and off just fine. i pulled the interior panel covering the back of the switches and actually pulled the wires off the switch for the exterior light but it stayed on. I pulled fuses and tripped all breakers and the light stayed on.............ended up pulling the bulb. any thoughts or know how to get a wiring schematic of our camper????? thanks a ton in advance!!
dsmvalley is offline   Reply With Quote
Old 11-13-2011, 05:34 PM   #2
Moderators' Assistant
bikendan's Avatar
your outside light should have its own separate switch. never seen it tied into other lights.
Dan and Shawn and Zoe the Wonder Dog
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 11-13-2011, 05:36 PM   #3
yep it has its own dedicated switch..........it worked before, but now even with the switch out of the picture the light stays on????............
Old 11-13-2011, 05:57 PM   #4
Lottery Non-Winner
Ovair's Avatar
Don't shoot me.....Just asking....
Does the light fixture itself have a small rocker switch on it? Are you sure?
I had one once that had a rocker toggle on it. Took me a year to notice it.
If the switch was in A position, the light stayed on regardless. If the switch was in B position, it was controllable by an inside switch.
Sounds kind of like what you are experiencing.
Anyhow, good luck.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
Old 11-13-2011, 06:06 PM   #5
hey no problem at all!!......not 200% positive but pretty sure as i pulled the lense to remove the bulb...........just a real shallow bezel to hold the lense.......you had me thinking tho for a bit
Old 11-13-2011, 06:33 PM   #6
Lottery Non-Winner
Ovair's Avatar
Maybe kinda sorta like this?
The switch might be on top. Mine was on the side. That was almost 20 years ago.... jeesh where has the time gone...??
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Old 11-13-2011, 06:40 PM   #7
thx for the pic, i dont recall one one on there as we always use the switch inside.........not sure, will swing by the dealer tomorrow to take a peek at one..........our TT is 150 miles away thx fer the pic!!
Old 11-13-2011, 08:15 PM   #8
Lou Amadio
herk7769's Avatar
Whoa Red Rider...
You say the light stays on even with the wires off the switch?
The switch in my camper to the outside light breaks the hot wire not the ground. Perhaps in YOUR camper it breaks the ground and not the hot wire. If so, your light has found another path to the frame. Could be a pinched wire.
If your light breaks "hot" then you must have taken apart the wrong switch.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 4)
herk7769 is offline   Reply With Quote
Old 11-13-2011, 08:47 PM   #9
jtstromsburg's Avatar
My trailer (2012 cherokee Grey wolf 28bh) has a remote that can operate the outside light. I had a similar problem one night and found I had turned the light on with the remote, which overrides the switch. Doesn't sound the same since you shut off power, but that is a 12v light, so would be on a fuse
Joel
2012 Cherokee 28BH Patriot Edition
2004 Suburban
jtstromsburg is offline   Reply With Quote
Old 11-13-2011, 09:09 PM   #10
Lou Amadio
herk7769's Avatar
Mmmm since I did not see a model year I assumed it was like my 2010.
I do not have a remote that controls lighting; just the wall switch.
So, you are saying the remote circuitry (if you have it) overrides and provides 12 VDC to the light regardless of switch position on the wall...
That would explain a lot.
» Online Users: 672
140 members and 532 guests
1l243, 4bnabird, ajgasman, akcampr, alphadog99, anitag, armye7, autorot8, Bearcat55, bidesheng, BigDogD, BigKidzFun, BigR, Bingo71, BJAY, BlakeB, BonnieSeip, bowtang2001, bush, Cafjackracing, Cairdeas2111, camper_Lucy, camping4us, campkng, CanadianCampers, Capsfloyd, carsonizik3, Cascade Bob, cdbus, cnkc, Dakota EV, dashonthedash, Dave_at_FastwayTrailer, daw592, ddemme, Derekcan, djorgensen3, dkwalsh, dnaraG_1M, doc73, donh, doosterhouse, Drmstx62, dtb7811, DTingle, EL99jl, elroseo, emljr, f1100turbo, Falcon35, feerobk, forthefunofit, fpdeod, FreedomTracker, gator14, gbowman143, growe, HemiCab, Interface Admin, IronJoce, itech, Itsthetwoofus, Janet H, jdefeo1, jechst, JedinWI, jerrygallion, jmswms, jnjh2012, jordan, Justbryguy, Kevin-and-Julie, kixonrt66, KKapa, KoolAide, KyDan, lacroixyvon, ldmcmahan, lesameinze, LFugate, Maddog378, martin73, MayorBobK, mbfree66, melbornj, msteeler, mtibod1955, NanaKaren, NINA, Nursx2, ohiobill, Old car, Pa-cj5, Papa Roo, Paul Short, pg_rider, pmsherman, Poppy Bill, pryner, punkaccountant, Puyallup, radurecka, rbrandon, realebill, Redheaded blue tick, Retired63, rickthelen, RJHuser, Sailfish Bret, samiller, sandpiper, savdog, Scriggs1, sideout1961, silverwing, SimchaSabre, snowbrid, southernsky, sphinx, steeleshark2, Team Wilhelm, Tee, Test Account, thom01, travyp, treadwelll, Triguy, trudinator, tshayn, TTNewbees, T_LMurphy, Vernk, Vette4trcr, vlite2011, wellcoman, whj77372, Wildcat Chris, win, y01lxb, yworrydog
Most users ever online was 944, 03-04-2012 at 01:27 PM.
Close [X]
