Formaldehyde and other out-gassed (or off-gassed) chemicals typically diminish with time...kind of like on a "half-life" schedule. A few months should do it.
Intense heat and/or high humidity will accelerate the out-gassing process. That's why it's worse in FL than up north. That heat MAY be accelerating the curing process.
Ventilation is your friend. If you are sealed up in a tin can with the AC on recirc so you recycle the same inside air, you our sealing in the contaminants.
Propane combustion also adds formaldehyde to the air. If cooking inside, be sure to use the range exhaust fan to remove combustion byproducts.
One other concern. Occasionally a product will come through that is not properly cured/finished at the factory. Foams in cushions, carpet and carpet padding and so on are particularly likely to be culprits, but so can fabrics, adhesives, laminate flooring, and so on. My mother was chemically injured (leaving permanent scarring in her bronchial tubes and lungs) from improperly cured carpet padding in her home. It took her years to recover a significant portion of her respiratory capacity...she never fully recovered.
These gasses are unhealthy, so you should do your level best to ventilate as much as possible and understand that the process takes time. There is no way to accelerate the curing of adhesives in wood products, foam, fabrics, flooring, and so on.
Most people handle occasional exposure to these chemicals fairly well. But some people are very vulnerable. Let your "nose" be your guide. If the smell is oppressive, limit your exposure. Ventilate, ventilate, ventilate.
BUT IF THAT FAILS, hunt down the culprit. A single bad item, like an improperly cured foam cushion on the dinette or mattress might NEVER cure. That's a manufacturing defect, and the item will relentlessly poison you.
If you suspect that's the case, then it's time to locate the offending item and get it out of your environment.
More on formaldehyde.
Testing devices.
Suggestions for dealing with formaldehyde.
CDC info on formaldehyde.
I am the former executive director of he New York Coalition for Alternatives to Pesticides. Our focus stretched to include indoor air contamination from synthetics, insulation, adhesives, and so on. I've testified before the EPA on the subject of chemical contaminants and human health. Don't ignore this. Each person is different, and if the smell is "oppressive" to you, that means it's harming you.
