Old 04-23-2015, 02:53 PM   #1
Stupid Spring Camping Question
Hi All,
We dewinterized two weekends ago but last night we had a frost warning. So I went to spend the night at our 5er which is permanently set up on a campsite. When i left this morning, I left the furnace on but really low (40degrees).
Is this ok to do? We will be going back to the campground on Saturday? What do others do in this situation, we can't be the first people to run into this problem.
We've never permanently camped before... i thought i should turn off the electric hot water heater, the propane and the water but maybe this isn't right?
thanks and best regards,
Chfranco is offline   Reply With Quote
Old 04-23-2015, 03:00 PM   #2
KyDan's Avatar
I would turn on an electric heater and set it on low rather than use my furnace.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 04-23-2015, 03:02 PM   #3
BamaBob's Avatar
X2 this is the heater we have for our 5er:
http://www.amazon.com/DeLonghi-EW770...ds=oil+heaters
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 04-23-2015, 04:06 PM   #4
I'm permanent and we always turn off the water, the water heater, the furnace and the electric heater every week. We leave the propane on for the fridge in case we lose power.
We've had overnight lows in the low 30's and it's never been a problem.
Iwritecode is offline   Reply With Quote
Old 04-23-2015, 04:11 PM   #5
dcheatwood's Avatar
I set furnace low on freezing nights to warm underbelly plumbling as well as inside. Also open cabinet doors to sinks plumbing. Electric heat will not warm underbelly hoses and tanks.
But "frost" does not mean freeze. You can get frost at 37°. You're probably OK.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 04-23-2015, 04:17 PM   #6
deebarjay's Avatar
what kind of trailer? ..... is it 3 or 4 season ?? and do you have shore pwr? ...setting your thermostat at 50* will keep the inside stuff frost free and not use too much gas at 28*-32*f.
deebarjay is offline   Reply With Quote
Old 04-24-2015, 12:51 PM   #7
I may have misunderstood your posting, but if you turn off your propane, the furnace will not work. Like others, I would use an electric heater on low. Thankfully it doesn't stay cold for long this time of year (28 and snow here two days ago).
DRiveWell is offline   Reply With Quote
Old 04-24-2015, 01:00 PM   #8
B and B's Avatar
We camped last weekend and had snow the last few days and below zero. The advantage we have is Diamond Edition with dark finishes. Trailer heats up in the sun and the inside never is below freezing due to latent heat stored. A few days a coupld degrees below I would not worry about it.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-24-2015, 01:19 PM   #9
LANShark42's Avatar
I won't leave my house with an electric heater on, much less my TT. That's one of the top causes of home fires. Seems like a GREAT way to lose your TT to a fire.
19xx Wife (named Melissa)
2014 Akita (named Mizuki)
2015 F250XLT 6.2l V8, 4x4, Supercrew, 3.73 Rear
10K WD Equal-i-zer Hitch
2015 Coachmen Catalina 273BH
LANShark42 is offline   Reply With Quote
Old 04-24-2015, 01:37 PM   #10
Unless you are leaving animals in your trailer, it shouldn't be a problem. Make sure the cord is not covered and nothing is near the heater and put it on low. No worries. If something completely freaky happens- that's what insurance is for
camping
