Old 10-09-2019, 07:57 AM   #1
Newbie Trailer Camper!
Stupid winterizing question
I can't rememember what I did last year. But I already opened the fresh water tank drain, opened the low point drains for hit and cold, took out the water heater rod and let it drain, and blew out the water lines with the air compressor adapter. And put some antifreeze down each drain and a little in each tank.
What I forget, is do I leave open all winter the low point drains, fresh water tank valve, and leave water heater anode out? Or do I close them all again? Thanks
onecrazyfoo4u is offline   Reply With Quote
Old 10-09-2019, 08:08 AM   #2
Flybob's Avatar
I leave all my drains open over the winter. Also check to see that there is no water behind your black and grey tank valves. OK for a little to be in tanks, but not behind the drain valve. Did you remember outside shower? Run the water pump for a second or two to get water out of pump and strainer as blowing the lines does not accomplish this. I would add antifreeze as an extra margin of safety however some people are comfortable with just blowing out lines.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-09-2019, 08:22 AM   #3
I like to put the anode rod back in mostly to keep the threads on the tank from rusting up. Finger tight is fine. Just have to remember to check it and tighten it up again in the spring.
Iwritecode is offline   Reply With Quote
Old 10-09-2019, 08:29 AM   #4
MillMitch's Avatar
toilet and pressure release button in city water outlet
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 10-09-2019, 09:19 AM   #5
Thanks for the replies. I did remember the shower, and did run the pump for a few seconds to push any remainder out. Good idea for the keeping the threads on the water tank, I'll loosely put the anode back in but leave everything else open. Thanks!
Old 10-09-2019, 01:24 PM   #6
rbq
Dud you remember to empty the water filter canister?
2014 Chevy Silverado
2011 Rockwood Roo 233S
rbq is offline   Reply With Quote
Old 10-09-2019, 01:32 PM   #7
My camper doesn't have a built in water filter, I just use the external hose adapter one. Thanks though!
Old 10-09-2019, 07:02 PM   #8
WFD
It was mentioned to run the pump a few seconds to get any water out...but the pump is used to suck up the antifreeze when winterizing so does that not accomplish that? Or was this mentioned just in case one only blows out the lines and does not use antifreeze?
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 10-09-2019, 07:08 PM   #9
After winterizing (blowing the pipes and running pink antifreeze thru all pipes), I also leave the faucet valves open. Just remember to close them all first before you hook up in the spring (don't ask....don't ask!!!!)
2019 Cedar Creek Silverback 37MBH
TV: 2017 Ford F350 CC DRW King Ranch
jd4010 is offline   Reply With Quote
Old 10-09-2019, 07:13 PM   #10
RBDTx's Avatar
What is a ďpressure release button in city water outletĒ?
RBDTx
RBDTx is offline   Reply With Quote
Old 10-09-2019, 07:25 PM   #11
WFD
At your city water connection, remove the screen inside there and you will see a little white button. Stand to the side and press it and it will cause antifreeze to shoot out there so that line has antifreeze in it. It will have pressure so stand to the side....don't ask me how I know this!!!
Old 10-09-2019, 08:28 PM   #12
Why not go ahead and tighten the anode?
After draining the water heater and flushing, I reinstall the anode and tighten.
Nothing to remember next year.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 10-10-2019, 08:20 AM   #13
Mostly because I didn't feel like getting the wrench and socket back out again.
It's possible that I'll be replacing it anyway. I might be able to squeeze a few more months out of it but I have a new one sitting in my storage compartment. I'll decide in the spring.
Old 10-10-2019, 08:40 AM   #14
Wondering how to run my AF through the lines without it going through my storage tank? I can’t seem to find a storage tank bypass valve?
2018 Cherokee
Cathi is offline   Reply With Quote
Old 10-10-2019, 08:45 AM   #15
Prime Member
I blow out my line AND add antifreeze. This ensures that the antifreeze doesn't get diluted with water still in the lines.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
Forever in my memory and in my heart. Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 10-10-2019, 08:50 AM   #16
Prime Member
2018 Cherokee
Does your camper have a winterization kit installed? This is just a length of hose with a couple of valves just before your water pump. This allows you to use your pump to suck antifreeze right out of the bottle anp pump it throughout your plumbing. Make sure your water heater is bypassed before you do this.
Old 10-10-2019, 09:13 AM   #17
Wondering how to run my AF through the lines without it going through my storage tank? I canít seem to find a storage tank bypass valve?
2018 Cherokee
2 ways...
1. Remove the suction line at the pump and add a temporary line/hose that will allow antifreeze to be pulled into the system by the pump.
2. Install an aftermarket winterizing/bypass kit.
Camco 36543 Pump Converter Winterizing Kit $11.99 (free ship)
winter
