Old 12-17-2015, 06:57 AM   #1
Super Strange Furnace Issue
I bought my Flagstaff 831RLBSS on Nov 4 and pulled it to Gulf State Park 3 days later. Used the furnace all month in Nov off and on occasionally. Used up one bottle of propane and it automatically switched to the other tank. Left trailer for a few days to return to Tn. Came back and when I turned the heat on the blower would come on and run a minute and shut off. I checked the propane tanks and filled the one empty one. Still no heat. Called warranty repair and they gave me 3 RV repair facilities. I called Cherokee RV and the service tech came out and checked the unit. He found that the switch on the furnace was turned off!!!!
So, how is this possible? I did not turn it off. I don't think I can even reach the switch with the init in place. I know I used the heat prior to this.
Strange things!!
2015 Flagstaff 831RBLSS
2015 Ram 2500 6.7 Cummings Crew
2014 Lowe Stinger 175
2013 FJR1300
Hthunder is offline   Reply With Quote
Old 12-17-2015, 08:02 AM   #2
Pickin' & Campin'
What furnace switch?
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 12-17-2015, 08:05 AM   #3
TURBS's Avatar
I agree what furnace switch?
Old 12-17-2015, 09:03 AM   #4
There is a switch inside the furnace that turns the control board on and off.
Old 12-17-2015, 09:04 AM   #5
TURBS's Avatar
Suburban furnace?
Old 12-17-2015, 09:06 AM   #6
Suburban furnace?
Yes it is a Suburban but I do not know the model number.
Old 12-17-2015, 09:18 AM   #7
A32Deuce's Avatar
FM!
A32Deuce is offline   Reply With Quote
Old 12-17-2015, 09:42 AM   #8
Left Coast
Originally Posted by A32Deuce View Post
FM!
X2
Old 12-17-2015, 09:53 AM   #9
TURBS's Avatar
Where did he access said switch?
Old 12-17-2015, 10:24 AM   #10
fonzie's Avatar
Usually on the side of the furnace......
Name:	suberban furnace on-off switch 1.jpg
ID:	96339   Click image for larger version
Name:	suberban furnace on-off switch.jpg
Fonzie
furnace
