Old 05-14-2008, 08:17 PM   #1
NINA's Avatar
Question Surround Sound Speaker
Got a surround sub woofer hooked up to a curtis home
theater system that the 2008 Grey Wolf TT came out with.
Got in behind the sub woofer speaker yesterday. One wire a black one
was not connected. White one was hooked up. The good old
pull down the lever and put the twisted wire end in and let go
of the lever so it contacts. Tried hooking up black and white,
switching holes, (only 2) no difference. I can tell you that my
sub woofer is not working, nor is surround speaker right or left rear.
Center and both front are working. Thanks in advance for any tips.
Nina
Bob & Nina's Bunkhouse
1970's Coachman Crusader 30ft TT
Add In: Sarina (18), Susan (14), and dogs Midnight & Shadow
Hitched up to a White 1999 F-150 Ext. Cab
Number of days camped in 2014-2
(4 more days reserved)
NINA is offline   Reply With Quote
Old 05-14-2008, 09:29 PM   #2
Cyber Phrenologist
Radio's Avatar
Go find a "D" cell battery and two pieces of wire about a foot long each. Strip back 1/2" of insulation on the wires, each end. Attach your two wires to the two speaker terminals. Hold the other end of one wire (doesn't matter which one) to the "-" minus end of the battery. Gently scrape the other wire across the "+" positve end of the battery. You should hear a crackling sound from the speaker. If not the speaker is defective. (or you're not getting a good connection for this test).
If the speaker crackles, then the problem is someplace else. Likely loose or missing wires.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 05-30-2008, 12:32 PM   #3
On the world famous Concertone radio units that we on here are so fond of, (ha ha), there is a wiring diagram on the top of the housing, when removed from the cabinetry. Your radio, IF it is a factory installed unit, should have one also. If it isn't a factory installed unit, it may not have the wiring provisions available for 5 speaker surround sound; or the sub, for that matter.GOOD LUCK !!! Randy
