If you want to hook up a sat. dish, you need a seperate cable. Some of the newer trailers have both, an inlet for park cable and sat. They should be marked as such. Will have two cable connections in wall at Tv. If I remember correctly, there were some posts about not running the sat signal thru the cable amplifier- messes up the signal I think. Other choice is to run a cable directly from your dish into the receiver.
