Old 04-18-2011, 04:20 AM   #1
Television Problem
Hi I just had my new Lacrosse luxury lite travel trailer delivered . I love it .
However , I can't get a thing on the tv it just say's no signal "anyone have any ideas?
Halfpint123 is offline   Reply With Quote
Old 04-18-2011, 07:16 AM   #2
MtnGuy's Avatar
1st of all, welcome to the forum.
Are you sure you have over the air TV stations in the area ?? Is the antennae up ?? Have you rotated it to different directions ?? Is the little booster button on the coaxial wall plate pushed in and the green lite on ??
Old 04-18-2011, 08:14 AM   #3
Television problems
The green button is on and the antenna is solid , can't move it
Old 04-18-2011, 08:31 AM   #4
Herk7769's Avatar
You have to pull the rotation collar (the one with the words UP and Down written on it) down slightly to rotate the antenna to point at the station's broadcast tower. The added black line points to the side of the mast with the plastic antenna head on it. All stations are now directional so you must use a web site like www.antennaweb.org to find the compass heading to the stations.
File Type: pdf Protractor used to align TV antenna.pdf (219.7 KB, 24 views)
HAM CALLSIGN - KC3FFW
Old 04-18-2011, 09:35 AM   #5
grhodes50's Avatar
Do you have the Jensen Omni Directional antenna? If so, make sure the tv is set on "air" and the booster switch is flipped to antenna and not cable.
This antenna does provide a nice clear picture, but it does have a limited range. How far are you from the station's broadcasting tower? Are there mountains or buildings between you and the towers that could cause interference?
Hope this helps.
Gary & Trish
2018 Nights Camped - 5
Old 04-18-2011, 10:51 AM   #6
Also, once you are sure the green light is on, and you aren't on the cable switch side, you must do a channel scan/search, ro allow the reciever to pick up the available channels in that area. I do this at every new campground. Randy
Old 04-19-2011, 05:35 AM   #7
Herk7769's Avatar
"Head smack" Yes, I should have mentioned that too. Thanks.
In fact, since the digital stations are very directional, every time you turn the antenna to a new direction you should rescan. You might be surprised at the new stations you find. (you also might lose some since you are not pointing at the old ones.)
Antenna Web will give you several headings for different stations if they do not use the same tower farm in your area.
Old 04-25-2011, 05:04 AM   #8
I do have an Jensen Omni Directional antenna, it can't be moved . the light under the cabinet is red and is on . How do I make the tv is on air ?
Old 04-25-2011, 05:38 AM   #9
Herk7769's Avatar
Post #5 answered your question.
Old 04-25-2011, 02:20 PM   #10
Herk7769 ,
I have the booster switch is set to ant. But how do I set the tv to air? It's a vizio tv.
