Old 01-10-2016, 09:13 PM   #21
ferguson65's Avatar
Originally Posted by reijo View Post
The switch is all manual. No auto functions
Reijo, please start you own thread for your issues and don't continue to hijack this one.....................
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
ferguson65 is offline   Reply With Quote
Old 01-10-2016, 09:51 PM   #22
Who Dares, Wins
doc73's Avatar
I ditched the legs and bought the pedestals like above for our mini lite we had. Worked great and was very stable.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 01-10-2016, 10:55 PM   #23
ferguson65's Avatar
I think that will be the route I take regardless of if I pay for it or FR does. I still need the table to double as a sleeping area occasionally, so fixed legs on it are a no go.
2013 F350 dually
Old 01-11-2016, 08:36 AM   #24
Wolverine 1945's Avatar
I can't imagine why 2 legs is not enough,,, it's a dinning table,,, not a work bench ???
Wolverine 1945 is offline   Reply With Quote
Old 01-11-2016, 08:42 AM   #25
Hi All. I have a problem, my rear lights (tail lights) and perimeter lights will not come on. I have 2016 Sunseeker 2401S only 7000 miles. Brake lights, turn signals and back up lights work as they should. I am lost for finding a wiring diagram for this model and the MBS sprinter manual only gives very simple map of the fuses and relays. Any body out there who might of had this type of problem, I would really be thankful for your input. Yes all the bulbs are good.
Maybe you are in the wrong forum,,, try searching under tail light problems,,, Good Luck !!!
Old 01-11-2016, 09:42 AM   #26
You are right, Sorry. New to this.
reijo is offline   Reply With Quote
Old 01-11-2016, 10:03 AM   #27
I agree. And any of the trailers I have owned with the chrome poles and fixed sockets as shown in these posts, could hardly be described as stable.
Are you sure you want to screw those floor mounted sockets to the floors in a laminated trailer? The floor in a laminated is foam sandwich and the upper layer of plywood under the vinyl flooring is only 1/4" thick or less. You're putting lots of faith in 1/4" plywood glued to a piece of styrofoam, especially when you start rocking it back and forth?
Mr Havercamp is offline   Reply With Quote
Old 01-11-2016, 01:28 PM   #28
Jack350's Avatar
Changed my folding unit to this post style. Very strong and easy to raise and lower. My slide floor is 3/4 plywood and I used t nuts.Click image for larger version
2017 Open Range RES 347, 2017 F-350 4X4 LWB 6.7.
Hayes Autoformer, Moryde SRE 4000, Andersen Aluminum hitch.
Jack350 is offline   Reply With Quote
Old 01-11-2016, 01:34 PM   #29
Ford Idaho's Avatar
Originally Posted by Jack350 View Post
Changed my folding unit to this post style. Very strong and easy to raise and lower. My slide floor is 3/4 plywood and I used t nuts.Attachment 97637
Attachment 97638
Attachment 97639
Attachment 97640
Do you happen to recall what size Tee nuts you used?
I also was the telescoping pedestal, How does it lock in place?
Old 01-11-2016, 04:21 PM   #30
Jack350's Avatar
I used 3/8 t nut with stainless screws. The support post has flip out clips and hydraulic assist.
