Old 11-21-2015, 03:20 PM   #1
thermostat closer to the actual temperature?
Is there a way to get the thermostat closer to the actual temperature?
oldgreymayor is offline   Reply With Quote
Old 11-21-2015, 03:52 PM   #2
wmcclay's Avatar
What thermostat
wmcclay is offline   Reply With Quote
Old 11-21-2015, 11:24 PM   #3
The dometic one in my fifth wheel. Digital.
Old 11-22-2015, 06:01 AM   #4
Oldgreymayor there doesn't seem to be a means to calibrate or enter an offset to calibrate. It difficult to receive a consistent temp in most coaches that have this new 4 season package because they use the furnace to heat most of the undercarriage which seems to leave less available heat at the furthest point. Also our heat thermostat sensor is located in the living room on the 3901 which is the closest point to the furnace. On a cold day we have a 7 degree temp difference from one end of the coach to the other.
Tim and Robin Lambert
2015 Sanibel 3901
2012 Dodge Ram 3500 DRW 4x4
tlamb6463 is offline   Reply With Quote
Old 11-22-2015, 07:35 AM   #5
Thanks, Tim. I was also having trouble with air coming on with furnace, but reset with mode and zone buttons and now it works great.
Old 11-22-2015, 08:36 AM   #6
Oh okay I misunderstood your problem. Glad to hear you worked things out.
2015 Sanibel 3901
