Old 05-12-2019, 09:13 PM   #1
SeaDog's Avatar
Tire rubbing upper inner fender
My friend stopped by asking for help his left rear tire had rubbed a hole in the covering of the upper inner fender. I measured the clearance there was less then 1/2 inch and the front tire had almost 2.25 inches. So I looked for a broken spring (none) then measured the clearance from the axle to the frame it was the same on both sides. When I removed the tire to get a closer look at the inner fender I got a surprise the tire I took off was about 2 inches larger in diameter then the others, but it was the same size according to the side wall markings. I think something let go inside the tire, hoping tire guy might shed some light on this. The tire on the left is the spare the right the one that was rubbing. I put his spare on and all is good to go.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 05-12-2019, 10:09 PM   #2
dcheatwood's Avatar
The inner tread has separated and will blow very soon if put back in use. Ask me how I know. When the tire is unmounted it will likely be oval instead of round. Finding it like this probably saved lots of $$$ in damage from a blow out. Good catch. I'd check the others to see if they are rounded out on the treads like this one, and replace them if they are.
2018 Forester 3011 DS
Old 05-12-2019, 10:29 PM   #3
Iwannacamp's Avatar
Hard to tell... the one on the left looks like a castle rock...the one on the right looks to have been replaced. IMO
As stated broken belt.
2017 Puma 297RLSS
Old 05-13-2019, 02:01 AM   #4
wmtire's Avatar
Yes, the tread belt is separating.
2011 Flagstaff 831 RLBSS
Words are powerful.
Choose them good.
Old 05-13-2019, 07:34 AM   #5
SeaDog's Avatar
My friend is having the tire replaced today. I put his spare on the trailer for the drive to the tire shop. I'm so glad we found this before it blew out. We are leaving today for a group campout. Yes he does have different brands of tires on his rig.
Retired Navy
Old 05-13-2019, 08:00 AM   #6
Brother Les's Avatar
imo...not a good idea
Brother Les
Old 05-17-2019, 07:30 PM   #7
SeaDog's Avatar
Back from camping with a followup. When my friend got to the tire store they found the right front in the same shape. I did not think to check the date code the tire shop said they were mfg in 2010 nine years is sort of stretching it. He replaced all four.
Retired Navy
Old 05-17-2019, 09:00 PM   #8
robbiels7's Avatar
Yep I have seen plenty of this. Click image for larger version
robbiels7 is offline   Reply With Quote
Old 05-27-2019, 04:21 PM   #9
Yep inner belt gave out, I had the same thing happen to a set of castle rocks on the family trailer we used to borrow. Caught it before leaving th driveway luckily
Sweedish15 is offline   Reply With Quote
tire
