Old 12-15-2008, 09:49 PM   #1
Tires
I have a 07 Flagstaff that had a set of CRT Tires on it. On the way to Destin Florida in November I had a Flat.After looking at the tires two other tires were bad. It looked like the thread was separating on them. I had to replace all of them. The only ones I could get at the time were the carlisle which were 4 ply bias tires. I am trying to find out how to contact the maker of the crt tires. They were made in o6 according to the dot number.Has anyone else had problems with these tires. They were all checked for air before the trip.
hberger is offline   Reply With Quote
Old 12-16-2008, 09:28 AM   #2
Head Rambler
I've never heard of CRT tires but then there are a lot of side branded tires I've never heard of. You should be able to look at the DOT code and who made them and where. Try this site. Tire Mfg Codes It's a bit old but has lots of Mfg's.
Gotta go campin!
Old 12-16-2008, 11:04 AM   #3
I had two Carlisle tires and two, what was marked on the tire as CART tire which are both made by Carlisle.
Old 12-16-2008, 10:27 PM   #4
Thanks for the information. I will try to get in touch with carlisle tires.
Old 01-17-2009, 10:46 AM   #5
CRT might just be...Carilse Radial Tire????
Denny & Rita
08 Rockwood 8243S
07 Dodge 2500 5.9L CTD
14k Pullrite SuperGlide/MorRyde pin box
wa8shc is offline   Reply With Quote
