Old 09-08-2014, 08:46 AM   #1
DocsDad's Avatar
Tires/Air Compressor
Do most of you have air compressors? Any recommendations on a portable, reasonably priced air compressor?
I can't get pressure in my rear tires. I believe the tires must be higher (need 80 psi) than the service station compressor can handle. I am losing more air than I put in.
DocsDad is offline   Reply With Quote
Old 09-08-2014, 09:29 AM   #2
I bought one at Sears for $99 and it has about 160 lbs of pressure,, it is flat and has a tank, works great takes about 1 second per lb. to fill or add air, also bought a straight fill tube for the inside duals Sears has it for $9 well worth it hope this helps you out
Jerry. Vietnam vet.
Retired
jgahlhoff is offline   Reply With Quote
Old 09-08-2014, 12:26 PM   #3
DocsDad's Avatar
Thanks jgahlhoff, for the input.
Old 09-08-2014, 12:50 PM   #4
Mature Citizen
downeyr's Avatar
Small Compressor
I bought one from Amazon for about $95.00. It is flat with an air tank and does the job. It isn't fast but size was the most important attribute for me.
Darlene, Ralph and Pippin
LTC (USA Retired), W7TLD
2023 - 199 days, 6966 miles
2013 - 2019 - 901 days & 37171 miles
2013 Georgetown XL 378 TS, 2014 Honda CRV
downeyr is offline   Reply With Quote
Old 09-08-2014, 01:29 PM   #5
Always Learning
I have this air compressor:
Porter-Cable 3.5 gal. 135 psi Pancake Compressor-PCFP02003 at The Home Depot
And use this air chuck:
NAPA AUTO PARTS
For duallies, make sure you get the one that is straight for the end one so that you can get to your inner duals.
Old 09-08-2014, 02:05 PM   #6
rattleNsmoke's Avatar
Hey Doug, I love your avatar...*s
rattleNsmoke is offline   Reply With Quote
Old 09-14-2014, 10:38 AM   #7
RSchleder's Avatar
I bought a KOBALT 'pancake" compressor from Lowes @ $129. It sometimes goes on sale for closer to $100 and, if not on sale, with a Military discount of 10% it's very competitive price wise. Read the 100's of reviews, you'll be sold just as I was!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 09-20-2014, 07:23 PM   #8
Powellr26's Avatar
I have the Slime 2x compressor that runs off coach or truck battery. One tire on my fifth wheel had a bad valve stem and I would lose 40 lbs of air every week or two. The slime compressor fills the tire to 80lbs in under 5 min. I bought mine at Amazon for around $75.00. Very powerful and compact.
Powellr26 is offline   Reply With Quote
Old 09-20-2014, 09:02 PM   #9
camaraderie's Avatar
I've been eyeballing this one at Lowes given the small size and extra accessories included. Have seen it as low as $89 on sale. Anyone have one and care to comment?
.3hp/2gallon tank.
Shop Blue Hawk 0.3-HP 2-Gallon 125-PSI Electric Air Compressor at Lowes.com
________
Cam
2015 Georgetown 280DS
camaraderie is offline   Reply With Quote
Old 09-20-2014, 09:17 PM   #10
RKR
RKR's Avatar
X2 on the slime. Very powerful and compact.
Sent from my high tech gadget
RKR is offline   Reply With Quote
Old 09-20-2014, 09:33 PM   #11
I have a Porter Cable pancake oiless comp works great 150psi.When I put a 2000 watt inverter in TV will be able to use any where.
2003 Dodge Ram 2500 5.9 Diesel
2014 Rockwood 2608WS
Big Paul is offline   Reply With Quote
Old 09-26-2014, 10:46 AM   #12
Have a 12 volt Puma that rocks
kssportsman is offline   Reply With Quote
tire, tires
