Old 12-20-2010, 05:32 PM   #1
tires and rims
I have a rockwood 5th wheel model 8283SS and would like to change my tire size from 205/75R15 TO 225/75R15. Can l use the same rims, l have the space between the tires and above.
My max pressure would go from 50 to 65 psi.
djahs is offline   Reply With Quote
Old 12-20-2010, 08:02 PM   #2
You need to determine the rim width, then you can go to the tire manufacturers web site to see what the recommended rim width is. Next you need to determine if the rims are capable of handling the additional air pressure.
Old 12-20-2010, 08:59 PM   #3
Herk7769's Avatar
Guys,
Do a search on the site for this topic.
It was covered at length about a year ago.
Need tires - upgrade to 16"?
Would be a good start
HAM CALLSIGN - KC3FFW
