Old 07-25-2011, 07:27 PM   #1
Toilet smell
I am getting a bad odor when I double flush my toilet. If I just do it once it does not happen but If I flush and the open a little while putting more water in the bowl I get a bad odor. This never happened with my other camper. Could I have a vent issue?
ndtiger is offline   Reply With Quote
Old 07-25-2011, 08:00 PM   #2
yvesm's Avatar
Is your exhaust fan running when you flush, if it is you can pull sewer gas out of the tank.
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 07-25-2011, 08:02 PM   #3
no
Old 07-25-2011, 10:55 PM   #4
Unlike a conventional toilet, RV toilets don't have a trap or a way to stop odors. When you do the second flush, you are letting the smell from your tank into the room. If you are trying to add more water to your black tank for the second flush, just hold the handle, or foot pedal, part way, to let more water ONLY in to the bowl, the when almost full, go all the way with a quick flush. I do hope you are keeping your black dump valve closed, and only opening for flushing every few days. Else you are trying to vent the sewer system through your toilet, and asking for other problems later on.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
