Old 10-23-2018, 09:49 AM   #1
Toilet valve
We bought a brand new 27REI and when pressing toilet flush lever sometimes it leaks on floor, right under the valve cover any ideas, Thanks
Granite State Camper is offline   Reply With Quote
Old 10-23-2018, 10:13 AM   #2
Islander's Avatar
'Granite State Camper'....
First off... Welcome to the Forum.
Seeing as your Unit is new it probably only needs to be tightened up.
Check the mounting screws and also the hose fittings.
After that if it still leaks I would remove it and check for a poor seal or missing 'O-ring / washer...possibly pinched during installation.
Perhaps someone with the same unit will chime in with better information.
Good luck
Islander
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles
Edge programmer, 4" SS exhaust turbo/back,
Tru-Cool Max Trans Cooler, Bilstein Shocks
Vancouver Island, B.C., Canada
Islander is offline   Reply With Quote
Old 10-23-2018, 10:26 AM   #3
Have dealer service under warranty, oops I forgot they try not to, bt force them to do it and do it correctly!
270S is offline   Reply With Quote
valve
