Old 09-13-2016, 04:40 PM   #11
Had the same problem with our Wildwood - eventually used a permanent marker to draw a line on the retracting pole just before the stop point and learned to stop just in time. Biggest problem I had after that was my ability to be distracted while retracting the jack!
Rockfossilman - Western PA
Rockwood UL 2604ws - Expedition 5.4L
Year-Days/Miles/Trips/Campgrounds
2013 to 2014-27/2444/7/7
2015-36/3245/8/9
2016-61/3277/9/10
rockfossilman is offline   Reply With Quote
Old 09-13-2016, 05:31 PM   #12
Stormrider151's Avatar
Originally Posted by awellis3 View Post
That's why most jacks (the ones I've seen) have a warning tape around the shaft saying, in essence, stop here. These motors aren't clutched so when the jack travel limit is reached, the motor binds and amperage soars as the motor continues to try to turn. My money is on operator error.
X2. The same thing will happen if you hold the button down on the power stab jacks after they stop retracting. Mine will pop a fuse every time.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 09-17-2016, 02:28 PM   #13
Most of the jacks don't have an electronic shutdown to keep you from over retracting. Hit the top or bottom too many times and the shock load will blow the jack head or break the drive. Always leave a half inch or so of breathing room. This goes for 5th wheels too, they can be just as easily damaged.
spaach is offline   Reply With Quote
Old 09-17-2016, 03:14 PM   #14
M109Rrider's Avatar
X14 on the circuit breaker. Stop by your favorite auto parts store and pick up a automotive auto reset style.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 09-21-2016, 08:52 PM   #15
Originally Posted by Scubanut View Post
X2 on the 30amp circuit breaker. Automatic reset if it trips. Fits in the same fuse holder as 30 amp fuse!! A bit pricy but if you constantly have those nuisance trips it's worth the $20.
2012 F150 FX4 Crew 5.0 3.73 gears
2O12 Coachman Freedom Express 292BHDS (outdoor Kitchen)
What is this "X2"of which you speak? I was unable to find it online. Thanks.
Jay
2015 Ford F-150 Crewcab Shortbed
2016 Rockwood A214HW
Bugsmasher is offline   Reply With Quote
Old 09-21-2016, 09:03 PM   #16
Scubanut's Avatar
Sorry, x2 means that I agree with the poster who was talking about the 30 amp circuit breaker.
These circuit breakers are readily available at auto parts stores. The ends are notched in some cases and you snap off the length you want. They fit in the same holder as your 30 amp fuse.
Name:	ImageUploadedByForest River Forums1474510150.070515.jpg
Scubanut is offline   Reply With Quote
Old 09-21-2016, 09:15 PM   #17
Mine popped the fuse last year after I retracted it too far. Since then, I've had no problems as I stop the travel when it reaches just above the height of the WDH bars.
2015 Shamrock 231KSS, Oyster shell
2016 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping in 2015, 45 in 2016
CNYCamper is offline   Reply With Quote
Old 09-21-2016, 09:21 PM   #18
Briorick's Avatar
After we bought, and brought, our new TT home we didn't realize the Dealer had retracted the jacks a bit more than needed. When we went to extend them down there was NOTHING, NADA, NIL. We soon discovered the fuse was blown. Once replaced we were good to go.
Now we are careful not to over-extend or over-retract the jacks. Was a good learning lesson though.
Rick & Brian
1 Happy Camper Pup ( Mya )
2016 Salem Cruise Lite 171RBXL
2004 GMC Sierra 2500HD LT 4x4 6.0 / 4:10
The best plans can be of those that happen in the spur of the moment!
Briorick is online now   Reply With Quote
Old 09-21-2016, 09:33 PM   #19
Scubanut's Avatar
I'm careful with mine too, but sometimes it even tripped when it was raining with no strain on it, in fact twice during the rain. That was the last straw for me!
Old 09-21-2016, 10:07 PM   #20
Briorick's Avatar
You are so right, it could happen at anytime! And usually the most inopportune time too.
I never knew these Automatic Reset Breakers existed. I definitely like the idea of them resetting themselves opposed to changing out the fuses. Have you experienced less, if any at all, "trips" since you installed the breaker fuse?
Rick & Brian
fuse
