Old 05-06-2011, 09:34 AM   #31
jimh's Avatar
try switching the wire from the microwave to a different breaker. may be a bad breaker.
i'm in the process of running a larger wire to my microwave because i changed to a convection/microwave.
another thought is to plug a light or something into the microwave outlet and see if the light works. if it does, try running the microwave (w/cup of water inside) and see if the light continues to burn.
i'm assuming the microwave is plugged in ie didn't get knocked out...
there is also a fuse in the microwave.
jimh is offline   Reply With Quote
Old 05-06-2011, 10:11 AM   #32
Originally Posted by cbrown View Post
What started all of this is when switching the breakers on the microwave would not turn on. Usually electrical is easy for me but this is just blowing my mind hahahaha!
Sometimes I think that we all need a circuit breaker between our eyes that can be reset when required !!! Seriously tho, if you have all the breakers reset to "on" and all the fuses are known good, and then still no power to your microwave then IMHO you have a problem somewhere else. Perhaps the microwave itself Good luck
...VTX-AL
VTX Al is online now   Reply With Quote
Old 05-06-2011, 11:01 AM   #33
frankm's Avatar
Originally Posted by herk7769 View Post
You have two "mains"; One 30 amps and the other 20 amps
I suspect all the "top" split breakers are off the 30 amp breaker and all the "bottoms" are off the 20 amp breaker.
herk7769, I'm not so sure about this, but then again electricity isn't really my forte. Why would a 30amp panel have two mains if there is a single bus? If you look at the picture closer and count the breakers and labels from the bottom up you find out that the second from the top breaker originally labeled A/C is now a spare and not a second 20amp main. I think.
Frank & Rita M
2016 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
frankm is offline   Reply With Quote
Old 05-06-2011, 11:03 AM   #34
Herk7769's Avatar
I did post I was wrong.
Do I need to start a thread to let everyone know?
HAM CALLSIGN - KC3FFW
Old 05-06-2011, 11:07 AM   #35
frankm's Avatar
Oh no, no, sorry!!!I'm usually one that reads all posts before posting a reply and I really goofed this one! (Ok, I've messed up a couple of times!) My bad!
Frank & Rita M
Old 05-06-2011, 11:13 AM   #36
CLASS "A" Senior Member
cfsoistman's Avatar
It's strange that they used a Tandem 30-20 Breaker as a 30 amp Main and a 20 amp breaker for A/C or anything else. I guess there's no electrical inspections when they build these things. A Regular Residential Main Breaker would have to be a standard size 30 amp single pole breaker, not a tandem breaker. Tandem breakers are no where as near reliable as a standard single pole breaker.
They use Square "D" Homeline brand in the RVs.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 05-06-2011, 01:14 PM   #37
Herk7769's Avatar
As I said before, it is availability, a desire to learn, and a reasonably good memory (so far) that keeps me here. I try to research every thread before I post, but I sometimes shoot, then aim. This was such a case.
Old 05-06-2011, 01:31 PM   #38
onetonford's Avatar
That is what I said in my post. Ive been a Industrial electrician for almost 20+ years and if you also notticed in the photo that some body put a new double 20 at the bottom and labled it ac in the wrong spot crossed it out and labeled the next one up as ac.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 05-06-2011, 03:02 PM   #39
Herk7769's Avatar
Wow,
Build a thousand bridges, but am I Pierre the Bridge Builder? No!
But just ...
well you get the drift.
Old 05-06-2011, 03:09 PM   #40
onetonford's Avatar
Most of the RV industry uses that style of breakers because of space saving they do have a standard to follow it is called RIVA.
2011 25 RL Wildcat
