Old 05-03-2011, 08:09 PM   #1
Trailer plugged into my house
Hey everyone this is my first post here I have a quick question I have a Cherokee light 28a, I am trying to get power from my house to my trailer how do I go about doing so. I have a connector that will connect a regular 110 line to the line in on the trailer. I was looking at the fuse panel and it showing me 2 breakers 1 being 20 and 1 being 30 on the main lines. to me that means 50 amp breaker I will need a 50 amp line coming from my house or I will be popping the circuit at my house correct? is there some type of invetor i need to switch so I can use the AC from house?
Thank you in advanced !
cbrown is offline   Reply With Quote
Old 05-03-2011, 08:15 PM   #2
Grape Escape
You can get an adapter for 30 amp cord to 15 amp at any camp store or Walmart.
Fine for charging battery, running lights and fridge.
Just don't run the air conditioning and electric water heat.
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 05-03-2011, 08:23 PM   #3
Is there an inverter that needs to be switched ? or does it switch automatically
Old 05-03-2011, 08:41 PM   #4
flyrotor's Avatar
automatic
flyrotor is offline   Reply With Quote
Old 05-03-2011, 08:53 PM   #5
Thanks guys
Old 05-04-2011, 08:22 AM   #6
So If i wanted to run the air and water heater I would need a 50 amp line coming from my house correct? Are most camp grounds now a days 50 amps?
Old 05-04-2011, 08:30 AM   #7
DF5.4's Avatar
You should be able to run the A/C on a 30 amp plug. The CGs I've been to have 30A at most sites. 50A is usually for the big class A and 5th wheels.
Doug
2011 Prime Time Tracer 3000BHS
2007 Ford Expedition
Reese Dual Cam HP Hitch
Nights Camped 2015-5 in TT
DF5.4 is offline   Reply With Quote
Old 05-04-2011, 08:49 AM   #8
In my fuse box I have two breakers on the main labeled line one is a 30 and one is a 20 does that sound right?
Old 05-04-2011, 09:32 AM   #9
The 20 amp fuse was probably added for the AC or water heater. Your Cherokee light is a 30 amp service. get the plug adapter from RV male to 110v standard wall plug, and you're in business. I personally even run my air on that setup, but just for an hour or two while unloading from a trip, at times. If you plug the camper into a GFI breaker at home; it may trip the breaker- some do, and some don't. I plug mine into a non GFI, and it works fine. Don't go any longer than the supplied wire, or usually the wires will get very hot. Good luck, Randy
Old 05-04-2011, 10:07 AM   #10
Randy do you know why the GFI outlets trip?
