Old 07-19-2016, 02:46 PM   #21
I take the hair dryer and heat the plastic cap a little, doesn't take much, and they come off easy.
Have a good one
grouchmore is offline   Reply With Quote
Old 07-19-2016, 02:49 PM   #22
pontiacdan45's Avatar
Send a message via Skype™ to pontiacdan45
So I bought a driver/wrench. It is a 20 volt battery and has 700 ft-lbs tightening and 1200 ft-lbs breaking. I tried various deep well sockets (1/2 in drive) and packed the driver and the sockets that fit the trailer and TV. DeWalt makes a good unit. I also carry a tork wrench.
Pontiac Dan
2015 Rockwood Signature Ultra-Lite 8289 ws
2015 GMC Crew Cab 2500HD Gas:
pontiacdan45 is offline   Reply With Quote
Old 07-19-2016, 04:37 PM   #23
Those are plastic caps. Had the same thing on my Salem. Just pry off. Bearing cap in the center comes of with the wheel.
jjuscg is offline   Reply With Quote
Old 07-19-2016, 07:30 PM   #24
Fooled me too
Yeah, I couldn't believe they would do that, so it fooled me for a while too. You were smart enough to ask. Kudos for that.
Plastic over metal holds in the moisture and guarantees rust. Even here in the southwest. Dumb idea. I took mine off right away.
mnoland30 is offline   Reply With Quote
Old 07-19-2016, 08:35 PM   #25
Jack350's Avatar
I use a DeWalt impact with a torque stick on all my lug nuts. Works perfect.
2012 Crusader 26RLD, 2000 F-350 4X4 7.3.
Hayes Autoformer, Correct track, Maxxis 8008E,
Andersen Aluminum hitch.
Jack350 is offline   Reply With Quote
Old 07-19-2016, 09:12 PM   #26
BDavis's Avatar
I concur with the torque wrench comments on aluminum wheels. Once reinstalled after 50miles and then every 500 is my system.
2016 Sandpiper 365asqb
2013 Rockwood Windjammer 3006W
2014 F250 6.7 PowerStroke 2wd
BDavis is online now   Reply With Quote
Old 07-19-2016, 09:27 PM   #27
SeaDog's Avatar
I have aluminum wheels and use a speed wrench (some call it a star) on 3/4 size lug nuts easy off easy on. When I put the lug nuts back on with the speed wrench (they call for 100 lbs torque) I over torqued all of them according to my torque wrench. guess I don't know my own strength lol
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 07-19-2016, 09:47 PM   #28
I keep a 24v cordless impact, breaker bar, and the correct deep sockets for the tv and RV. I also keep a Trailer Aid in the RV. Can change a RV tire like a nascar team! Lol.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Stock for now.
Days Camped 2015: 17
Days Camped 2016: 28 so far
DocGTO is offline   Reply With Quote
Old 07-19-2016, 10:11 PM   #29
DustyRoads's Avatar
I have a 1/2 Breaker Bar and 1/2 Torque wrench purchased from Harbor Freight. Low cost and they work great. I must admit that after we just bought our new 2017 Surveyor 251rks I didn't check the lugs before we left home. Good thing nothing happened because I didn't have the right size socket. If you buy a socket try to make it a 6 point and not a star. My lugs are 3/4 inch. I have an extension for socket that I also use for taking out the anode rod for the hot water heater.
2017 Forest River Surveyor 251rks
2013 Chevy Black Diamond Avalanche
DustyRoads is offline   Reply With Quote
Old 07-20-2016, 01:07 AM   #30
Campground host Mo. State
Photogirl's Avatar
We always carry a torque wrench and proper socket, and check lug nuts before pulling out on the road. we always find at least two nuts a little loose.
Frank & Kathy & Daisy 2.0 Yorkie (Pack leader)
2008 Ram 6.7 Diesel, 4.10 diff., EGR valve delete, MBRP straight exhaust, Mini Max race tuner,K&N Cold air
2016 Crusader 321 RES
Days camped in 2015 111
Photogirl is offline   Reply With Quote
tire, trailer
