Old 08-17-2010, 02:04 PM   #1
Transfer switch
Is there a transfer switch in the 2004 georgetown se model 303? If so where is it located? Thanx
kaptkronos is offline   Reply With Quote
Old 08-17-2010, 02:27 PM   #2
Transfer Switch
If you have a transfer switch you wouldn't have to plug your coach into the receptacle when you run your generator. It would automatically switch from shore power to the generator. If you have to place your power cable into the outlet inside the rear baggage door then you don't have a transfer switch. Hope this helps.
Crossfire is offline   Reply With Quote
Old 08-17-2010, 02:54 PM   #3
Thanx for the info.
