Old 03-29-2009, 04:42 PM   #1
ben
transmission and towing ?'s
hello all
i started this thread because i had some ?'s about my truck and TT.
let me give you all the info i have:
2001 dodge ram
2 wheel drive
318 c.i.d. motor 5.2 L
with towing package
quad cab with a fiberglass cap
gvwr 6400 lbs
actual weight 5660
newly rebuilt trans
motor has 120,000 miles and I've always have used 10w-30 full synthetic Valvoline oil, does not burn any oil
3:92 rear end
gawr rear 3900 lbs
gcwr 12,500 lbs
and the gs272:
total length 30 foot
1- 30 gal. fresh water
1- 30 gal. grey water
1- 30 gal. black water
dry weight 4657 lbs ( i haven't weighed it myself yet for actual weight yet )
1 slide ( middle ) dining room
center kitchen
rear bedroom
2- 30 or 40 lb propane tanks ( cant remember which )
tandem axle aluminum frame
i guess my real question is does anybody think that I'm overloading my truck ?
everything that I've read says that i can pull 7550 LBS.
thanks for any advice
jcarr56506 is offline   Reply With Quote
Old 03-29-2009, 06:01 PM   #2
Knower of Some Things
Should be OK, just don't go blasting through the mountains or do 80 down the highway in a headwind. In other words, just don't get stupid, and you, your trailer, your truck, and your family should ought to be safe.
PumaPro is offline   Reply With Quote
Old 03-29-2009, 07:54 PM   #3
ben
thanks, around detroit there arent very many hills and the pot holes are so big i doubt i could go past 60
Old 03-30-2009, 06:59 AM   #4
I have a 95 Ram 1500 club cab 318 with the 46RH overdrive tranny and lock-up converter. My advice to you is at the very least install a transmission cooler. A bigger radiator would also help, but these Dodge tranny's worst enemy is HEAT. My rear diff is a 3:54, good for gas savings/mileage, NOT so good for pulling stuff. 3:73 or 3:91 would certainly be much better for towing. Also use synthetic fluid, and keep up with flush/filter changes, and you'll stay a happy camper. Hope this helps, Randy
Old 03-30-2009, 08:01 AM   #5
hunt4240dw's Avatar
Send a message via MSN to hunt4240dw
I would also get some kind of trany temp gauge.
David
The Hunts
2012 F150 Ecoboost, 3.55, tow package
Equal-i-zer Hitch
2009 Flagstaff V-Lite 30WRLS
1982 16' Glastron Ski boat
hunt4240dw is offline   Reply With Quote
Old 03-31-2009, 06:55 PM   #6
ben
well Ive got a trans cooler that came with the factory tow package, should i look into a second one ? i have a 3:92 rear end in mine. also Ive heard that you cant switch to syn after you have used standard fluid. i was thinking about that lucas additive for transmissions. what do you think ? as for the temp gauge i hope to be installing that this season, it looks easy enough to do myself.
Ben
Old 03-31-2009, 07:16 PM   #7
ben
i forgot to give the wheelbase of the old girl, i just went out and measured and from center to center of the tires is 140" and i have stock size tires but i put LT's on instead of the standard P series
thanks chap
Ben
Old 03-31-2009, 07:19 PM   #8
Dodge Guy's Avatar
I would forget about any type of additive for anything. your Ram will do just fine pulling an approx. 5900lb readt to travel TT. you can switch back and forth between syn. and conventional oil any time you want. it will not hurt it. the factory trans cooler will be enough for towing.
I used to tow a 6500lb loaded 28ft. TT with a 97 Dodge conv. van with the 5.9L and 3.90 gear. it did a great job of towing it, even through the Rockies on our trip to Glacier National Park! it also had the factory tow pkg. so the factory stuff is good. with the Quad cab you will have a good wheelbase for towing. I too put LT tires on my van, so that is a big plus for you also.
BTW, if it makes you feel better, I`m a Chrysler Jeep Dodge tech so I can say with experience that these trucks are workhorses!!! it sounds like you take very good care of your truck so I don`t see you having any issues with it. you may want to replace the fuel pump just as a precaution to avoid a break down. they were known to go bad on the trucks. also keep an ear out for the rear end making noise. this was another area that failed early towing or non-towing. the pinion bearings would fail and you will hear a growling noise from the rear axle. I`m not trying to scare you, just trying to save you from a breakdown while on a trip.
Good luck!
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 03-31-2009, 09:18 PM   #9
TulsaSteve's Avatar
A shout out to the Lucas Tranny additive. It's like pouring maple syrup into your tranny, but the stuff works like a dream... Amazing stuff.
TulsaSteve is offline   Reply With Quote
Old 04-01-2009, 07:52 AM   #10
Yes, I agree that you should not have a problem with that combo. with the factory tow package and cooler, you already have a good towing setup- although the 318 is a little weak, but the 3:92 gears should take care of that. Also your wheelbase is okay for towing. The Lucas additive is great stuff! Randy
