Transmission Issue
2001 georgetown 32.5 V-10 - Just this afternoon on our way thru the White Mountains as the transmission shifted down from the normal drive gear to assist in a climb we began going slower and slower rather than moving along up the incline. The engine races normally as if it has done what its supposed to do but there is no increase in forward moving power. Also there is a pinging/high pitch rattling noise. seems fine in the regular drive gear no noticible odd difference from normal operation jsut when shifting down on the run. Stopped put the tranny in all gears and stepped on the gas holding the brake down and there does not seem to be slippage. Transmission fluid level is full. Any ideas or has any one experienced this issue? COuld this just be bad gas or is it a tranny issue. Everything seems fine and normal in regular drive gear. Thanks
