Forest River Forums
Sunline User Photos
Old 04-07-2009, 02:15 PM   #21
Those seem to be normal temps, even at 180ºF you're not hurting your unit unless you drove it for thousands of miles that way.
Grand Surveyor GS-280 Pushing a 2500 Mega-Cab CTD!
Nights camped in '10 (Not Nearly Enough!)
Old 10-24-2009, 09:17 AM   #22
Hipshot's Avatar
I just returned from Elkhart IN with a Rockwood 2604SS. TV is a 2008 Silverado 1500 4X4 LTZ 5.3 3.73 rear and towing package. On the trip to Elkhart trans temp was around 150-160 in drive 19 mpg. On the trip back towing the 2604SS at 60mph in drive cruise control on trans temp 180-190 and shifting on every hill, sometimes down to second gear at 4000 rpms, 8.5 mpg. After about 100 miles I shifted to third 2600 rpms, cruise control off at 60 mph trans temp 155-164 rarley shifted and 9 mpg.
Hipshot is offline   Reply With Quote
Old 10-24-2009, 09:41 AM   #23
Moderator
mtnguy's Avatar
I very seldom use cruise control while pulling my trailer. I get much better gas mileage by loosing a mile or 2 on the speedo going uphill then the cruise control keeping the speed. If using the cruise control, then I feel compelled to lock out OD to keep the shifting under control.....which means more RPMs and worse gas mileage. In the rolling hills around here, I will leave the OD on, back off on the gas pedal a little on hills, and shift out of OD when I figure the tranny is ready to shift for itself. I do watch my tranny temperature via a ScanGauge II.....remarkable little instrument.
About the chart on post #1. I never noticed before, but that is the "average" temperature. My truck averages 150 to 170 pulling my Surveyor, but has gotten up to 200 on a long, hard pull up a winding moutain pass here. So my average should be pretty close to 160 or so, with the occasional spike under hard pulling conditions. A little relief to know that.
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
mtnguy is offline   Reply With Quote
Old 02-08-2010, 09:36 PM   #24
gauge clusters
I do like the gauge mounting package for the top of the dash!! This looks so much better than a pillar mount. Even if you don't purchase the Aerotech gauges, I am sure that their dash mount kits would work with the correct diameter gauges of another manufacturer.
CAN-DO
CAN-DO is offline   Reply With Quote
Old 04-26-2010, 04:02 PM   #25
My toyota tundra has the c& h but it never wiggles pulling the camper nor does the eng temp gauge either even on the hottest days pulling through the adirondak Mtns it seems to do just fine
Santaclause is offline   Reply With Quote
Old 04-27-2010, 08:48 AM   #26
Lou Amadio
herk7769's Avatar
I talked to my GMC about this very issue. I have the Allison transmission and I occasionaly pull my rig into the "hills" of PA.
My D.I.C. trans temps can get into the 200 - 220 range but rapidly fall back to 180 - 195 on the back side of the climb.
Normal temps on the highway 160 - 170.
I never got the warning on the DIC. So I asked when it was set to come on and they "thought" it was 250. They said if it even came on I needed to pull over and let the tranny cool down and bring it in for service (filter-fluid change) when I got back from the trip (no real need to rush; just get it done soon as I get back).
They said the Allison was built like a tank and would provide may years of hard service with regular maintenance.
Neat that the Allison has an external spin on filter.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Slide-rite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: Still Grounded)
herk7769 is offline   Reply With Quote
copyright 2006 - 2010
Close [X]
