Old 02-26-2015, 10:09 AM   #1
wfmdfm's Avatar
Trip ended the day it started
I started my trip Massachusetts to Florida yesterday but I was back home last evening. At my second gas stop as I was standing filling up I looked down at the driver side trailer wheel and its damaged and covered with grease. i am thinking I must have hit a frozen snow bank at some point after my last stop and damaged the hub. The wheel cap and bearing hub were both missing. The bearing was fried and damaged the spindle. All the bearing were checked and lubed in the fall anticipating this spring trip. 3 weeks lead time to get a new axle and ship it to the RV dealer doing the work. Had I not needed gas this could have been big trouble. So I cleaned out my stuff packed it all in the truck and headed back home. Our plan in Florida was to watch my daughters collage softball week long tournament. Last night we were scurrying to make plane reservations, book a place to stay and get car rental. YUK !!
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 02-26-2015, 10:15 AM   #2
ryand's Avatar
That stinks. I had a similar experience and know the feeling. Good thing you caught it.....it likely would have resulted in damage to your rig and possibly others.
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 02-26-2015, 10:32 AM   #3
(Dry Huunday)
DreiHunde's Avatar
That sux! But the great thing is everyone is safe!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 02-26-2015, 10:47 AM   #4
Ret E-9 Anchor-clanker
donanddona's Avatar
Mine smoked a bit more. I did emery cloth the spindle, pressed new races in the hub packed bearings and were still chugging along. Makes good Campfire stories.
ID:	70317   Click image for larger version
ID:	70318   Click image for larger version
ID:	70319   Click image for larger version
donanddona is offline   Reply With Quote
Old 02-26-2015, 10:58 AM   #5
donanddona's Avatar
Just another picture(s) thought. When pumping grease in the EZlube axels and you find unhealthy grease the bearings will require, removal, cleaned and inspection of bearings hub, and races, both inner and outer. Repacking and new seals.
Last is a good healthy looking bearing. This can easily be seen by removing the center cap (Phillips screw) of the wheel and then removing the dust cover (slip-joint pliers). Just look and decide.
ID:	70321   Click image for larger version
Old 02-26-2015, 11:42 AM   #6
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by wfmdfm View Post
All the bearings were checked and lubed in the fall anticipating this spring trip.
I'd make damn sure the tech who worked on that trailer properly checked and installed those bearings. Some mechanics don't know how (or don't bother) to properly set the preload on tapered wheel bearings. It requires a torque wrench usually set to 50 foot pounds to seat the bearings.
Now before all you DIYers out there call BS, "you just crank 'er down hand tight with a 12" wrench" remember, I'm talking about folks who charge other people to do this job. Working on someone else's wheels and putting their lives in your hands is a whole 'nother thing. What if the OP or a family member had been injured or killed and the subsequent investigation found the improperly installed bearings were at fault? You want to be the guy with the grease on his fingers? So ...
1) Tighten castellated nut to 50 foot-lbs. while rotating wheel
2) Back off nut, do not move wheel
3) Retighten nut finger tight, do not move wheel
4) Back off nut to first spot to bend tang or insert cotter pin
5) The nut should be free to move, retained only by bent tang or cotter
pin.
If not done properly, bearings will expand, overheat, melt grease, seize, score spindle and finally disintegrate.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 02-26-2015, 03:10 PM   #7
Sorry to hear about the problem, but could have been worse. Have a safe trip.
RLHAMILTON is offline   Reply With Quote
Old 02-26-2015, 03:42 PM   #8
I did not have this problem but I had my 3rd axel fall off while driving on the freeway. It was on my older Ragen toy hauler and the axels were being held on by 1/8 plate and the welds all broke. The only thing keeping the axel from being in traffic was the shocks stayed attached. Thanks Monro. When this happened it caused exes strain on the king pin busting welds on it. It took 6 months to get my rig back because nobody wonted to admit blame. Finally my insurance paid to repair and replaced all three axels with an upgraded suspension and had the king pin replaced. I traded it in as soon as I got it back for my forest river 5er.
j free is offline   Reply With Quote
Old 02-26-2015, 03:45 PM   #9
Looks just like mine did about five years ago. I did the exact same thing myself in terms of repair. hAD THE NEW PARTS IN ABOUT THREE DAYS ... brake drum,shoes and all the rest. It worked out well.
grayfox is offline   Reply With Quote
Old 02-27-2015, 09:13 PM   #10
Crockett's Avatar
pin.
Thank You!! The dexter vid shows this but so many online vids don't. Simply advising to back off a 1/4 or 1/3 turn is WRONG!
Crockett is offline   Reply With Quote
