Old 06-07-2011, 10:10 PM   #1
Trouble with Electrical System
Can any one help our travel trailer 2000 will not work when plugged into 110 outlet It has been working fine until now, nothing works refrigerator will not work, however we plug in our handy vac. into the same plug in it runs, It must be simple,however we are not seeing it we have checked out the breakers and they are working fine, Any comment thankyou Ella
Ella is offline   Reply With Quote
Old 06-07-2011, 10:16 PM   #2
Herk7769's Avatar
Ella I made a new post so we can work these issues without confusing the two problems.
So, you say "nothing works" yet you go on to say the outlets have power.
I am confused.
HAM CALLSIGN - KC3FFW
Old 06-07-2011, 10:54 PM   #3
jimh's Avatar
the outlet u plugged the handy vac into; is it the same one u plugged the trailer into?
what kind of trailer...is it 30 or 50?
does it have a battery disconnect switch (mine is a red key near the fuse panel)?
jimh is offline   Reply With Quote
Old 06-07-2011, 10:58 PM   #4
Hi Lou, I should of said the appliances will not come on, however the light work, and when we plugged the vac into the refrigerator plugin it worked. My husband was checking the batteries when I was e-mailing He had only checked one battery assuming the other would be charged if the one was, however the one battery is not charged so he put the charger on it hoping that maybe our Issue .. Thanks for the answer back Ellad
Old 06-07-2011, 11:08 PM   #5
HI JIMH, The outlet we plugged the vac into was for the refrigerator, outlet. our trailer is a 2000 Salem 26 ft pull, no disconnect switch( that we know about) Thank You for the reply
Ella
Old 06-07-2011, 11:26 PM   #6
jimh's Avatar
the battery may be ur problem. although, i would have expected the converter to put out enough to give the control board on the frig enough power to work. maybe not...would like to know how u come out.
Old 06-08-2011, 06:37 AM   #7
Herk7769's Avatar
If one battery in a 12 volt bank has a cell that is shorted internally, battery bank voltage will be much less than 10 volts. No 12 VDC; then no appliances (AC or otherwise since 12 volts is a must for fridge).
Remove the bad battery from the system and check Converter output for 13 volts. If no converter output the converter could have been damaged.
Old 06-10-2011, 06:46 PM   #8
electric trouble Salem 2000
Hi, I would like to thank all for your help. My husband rechecked the batteries and found one was not charged at all, charged the battery all seamed to work, but he air and our built in radio, he pulled the radio found a loose connector , still no air, this went on for about one day, I told him I could smell something hot Like electric wire, we started checking, our extention cord was loose at the plug and causing the breaker to pop on our gfi plug in therefore no air. now all is solved thanks for all Imput.. Ella
