Old 05-18-2016, 07:22 PM   #1
Lilredram's Avatar
Question tst507 tpms problem????
Hi all
I have a tst 507 4 sensor system for my 5er tires. I've got the sensors programed and the pressure set (85psi high/75psi low) 4 tires show up on the screen (along with one extra on the tv, don't know why?) My problem is that the tires show up but no pressure or temp settings. Is this normal? Shouldn't there be something other than the tire symbols blinking one then the other repeatedly. I thought you would be able to see pressure and temperature settings for each tire for so many seconds then switch to the next tire then repeat. I don't know if I did the setup correct. The instructions were pretty vague. Any help would be greatly appreciated.
Thanks RonG
__________________________________________________ ____
2017 CC Silverback 29RE / UVW (dry wgh't.)=10,705 lb
Pin wgh't.=1,985 lb / GVWR=13,985 lb
2016 Ram Delmonico Red 2500 CC 4x4 6.7L Cummins
with rear air suspension 68RFE 6spd Auto 3:42 axle
Gvwr=10,000 lb GCWR=23,300 lb payload
Lilredram is offline   Reply With Quote
Old 05-18-2016, 07:25 PM   #2
Just call TST and tell them what you posted and they will walk you thru the whole setup. Fantastic service.
Old 05-18-2016, 07:29 PM   #3
Flybob's Avatar
It takes a while for the first readings to show up. Sometimes as much a 5 mins ( estimation). They may not all show up at the same time. Once they show up they will stay up-to-date. You might also want to expand your pressure range especially on the high side. The pressure will increase with driving and road/ambient temp. If you are starting at 80 you might need to go closer to 95. You may have to experiment. The numbers are more relative than exact. You will be really with this system.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-18-2016, 07:34 PM   #4
Lilredram's Avatar
Thanks guys, I'll give tst a call, and reset the pressure.
Old 05-18-2016, 07:44 PM   #5
jtownstumpjumper's Avatar
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
I think they recommend 20% on the high side and 10% on the low side...your 85/75 settings wouldn't last long once you hit the highway without alarms going off......if you are starting with 80 psi on a given day don't be surprised if that changes daily just sitting on the driveway by a couple pounds up and down due to changes in daily temperature, sun on one side , shade on the other, these all effect the tire pressure.....the company's customer service is the best.
Lloyd & Kathy & Kit(19 yr old cat)
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014 - 38 nights/3500 mi.; 2015 - 66 nights/6260 mi.; 2016 - 44 nights/6106 mi.
2017-65 nights/6992 mi.; 2018-7 nights/1037 miles....9 nights booked
jtownstumpjumper is offline   Reply With Quote
Old 05-18-2016, 07:49 PM   #6
Kenny kustom's Avatar
I had mine aired to 80. Regularly saw close to 90 psi.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
